Old 03-11-2019, 05:44 PM   #1
KiWinUS
KiWinUS's Avatar
Default K.R.Wilson box refinishing
I have several KR Wilson tools in wooden boxes including distributor timing tools , what can I put on the wood to make it look nice & original. I do not want to over restore just look nice
Thanks
Old 03-11-2019, 06:18 PM   #2
DavidG
DavidG's Avatar
Default Re: K.R.Wilson box refinishing
How about some simple wood sealer rather than varnish?
Old 03-11-2019, 06:37 PM   #3
cas3
model T spokes we treat with a 50/50 mix of turpentine and linseed oil. it will darken the wood a slight bit, but soaks in good. takes a day or two to dry
Old 03-11-2019, 06:41 PM   #4
banjoQ
banjoQ's Avatar
If you are or know someone who is a wood worker, try the "Good Stuff". You will need to go to a real lumber yard or wood working store to find it. I've never seen it at the big box stores. It's an oil based polyresin that leaves a satin finish. Just clean your surfaces and wipe it on with a clean rag. cleans up with mineral spirits. I have used this many times in the refinishing of antique furniture and swear by it. Sounds like just the thing for your project. good luck.
banjoQ is offline   Reply With Quote
Old 03-11-2019, 06:49 PM   #5
JSeery
JSeery's Avatar
I used linseed oil on Civil War Reenacting wooded objects.
Old 03-11-2019, 06:54 PM   #6
expavr
expavr's Avatar
I used WATCO Teak Oil on the bed of the truck. It shows the color and grain of the wood without the over restored look of varnish or polyurethane. It will darken as it ages leaving a nice "used" look patina.
expavr is offline   Reply With Quote
Old 03-11-2019, 08:42 PM   #7
Craig CT
Craig CT's Avatar
Thanks
Hi KiWinUS; You might try some small areas on the bottom of a box if you want to try some different finishes. Good luck, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 03-11-2019, 08:55 PM   #8
Tinker
Tinker's Avatar
Linseed oil is great. It will take sometime to dry. But it'll soak in to the wood well and it will look natural to the age.
Clear danish oil isn't bad either.
Old 03-12-2019, 03:54 AM   #9
KiWinUS
KiWinUS's Avatar
Thanks so much for all the suggestions guys.
Cheers
Tony
Old 03-12-2019, 07:00 AM   #10
r_reed
r_reed's Avatar
if you try linseed oil, best get "boiled linseed oil" (comes ready to use), my understanding is raw linseed oil takes forever to dry. also, if you use linseed oil (normally thinned with a little terp or min spirits) wipe if off several times over the first day or two.
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 03-12-2019, 09:01 AM   #11
Drbrown
Drbrown's Avatar
The old-time wood finishers of high-end projects used "Tongue Oil" for wood work in quality homes and on furniture. I specify it for quality restoration building projects. Not sold everywhere, I found it in my local Ace Hardware store. I used it on my antique doors that have been stripped and ultra-fine sanded. Rub on bare wood and apply at least 4 or 5 coats, (more the better) allowing each coat to soak in and air dry. When fully sealed, the wood will not accept any additional coatings and will reject water. Its a very durable and easy to clean/restore flat finish.
Drbrown is offline   Reply With Quote
Old 03-12-2019, 10:22 AM   #12
5851a
Do you know or anyone know how they would have came when new?
5851a is offline   Reply With Quote
Old 03-13-2019, 01:43 AM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
Yes, use boiled linseed oil it will dry fairly quick.
Marvin/TN is offline   Reply With Quote
Old 03-13-2019, 04:56 PM   #14
JSeery
JSeery's Avatar
Good points! If not done correctly it can leave a finish similar to honey!!
Old 03-14-2019, 01:48 PM   #15
supereal
supereal's Avatar
I have a number of tools from many years ago, as well as a machinist's tool box complete with a small notebook containing his notations during his career. The boxes are covered with stains from oil, dirt, and who-knows-what. I left left them just as I found them as a tribute to their history.
supereal is offline   Reply With Quote
Old 03-14-2019, 02:19 PM   #16
Shu47
Shu47's Avatar
I am by no means an expert but I would use linseed oil.
Shu47 is offline   Reply With Quote
Old 03-14-2019, 07:58 PM   #17
Gary in La.
Gary in La.'s Avatar
The KRWilson catalogs always say "varnished oak case". The question would be (what shade?)
My KRW cylinder plug gauge box shows it had one light coat of varnish on the inside cover lid only before the decal was installed. The rest of the inside was not varnished and of coarse the outside shows the usual darker oil staining and dirty hand coating.
Gary in La. is offline   Reply With Quote
Old 03-15-2019, 01:38 PM   #18
Ross F-1
Ross F-1's Avatar
If you use linseed oil, always toss the rags you applied it with into a fire safe container. The combination of cotton and linseed oil self-ignites, has burned down many shops!
https://www.wwlp.com/news/local-news...ays/1847556484
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-16-2019, 10:25 AM   #19
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
I prefer lacquer on my wood carvings, usually 3-4 coats flattened with 4-0 steel wool. Durable and a nice soft effect
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
