Old 07-20-2021, 05:01 PM   #1
rayro39
rayro39's Avatar
Default Looking for 1939 Ford Deluxe cardboard door panels
Does anyone reproduce these or should they be made from scratch. If so what is the best material to use.
Thank You!
rayro39 is offline   Reply With Quote
Old 07-20-2021, 07:14 PM   #2
swoopNZ
MEMBER EMERITUS
Default Re: Looking for 1939 Ford Deluxe cardboard door panels
Easily made up from flexible fibreboard.
Any upholsterer shop should have it.
swoopNZ is offline   Reply With Quote
Old 07-20-2021, 07:34 PM   #3
aussie merc
aussie merc's Avatar
dont like useing that pasteboard or cardboard type stuff i use 3mm [1/8] 3ply moulding ply bends easy enough and is real tough cut to size then seal them trim some work but worth it lasts 4 ever and a day not affected by humidity
aussie merc is offline   Reply With Quote
Old 07-22-2021, 03:29 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Thank You!
The only thing I have used to make from scratch is 1/8" luan plywood, available from Home Depot as well as other sources.
Old 07-22-2021, 10:38 PM   #5
Detonator
Detonator's Avatar
I've always used luan. Just make sure the grain is going the right direction for any curve in your panel.
Seabright Hot Rods
Detonator is offline   Reply With Quote
