Old 09-14-2020, 08:17 PM   #1
PalAl
PalAl's Avatar
Default Cleaning Silvered Plated Lamp Reflectors
Doing a search I came across an article about Cleaning Silvered Plated Lamp Reflectors from Mr. Bob Bidonde dated December 1999, going to give it a try as my reflectors have a dull like coating on them but appear to have a shine under that film. Thank you Mr. Bob any other tips before I dips?
Any other ideas would be appreciated especially if you have done this and it worked.
Yes... I know I can buy new ones, but where is the fun in that
Thanks
PalAl is offline   Reply With Quote
Old 09-14-2020, 09:10 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Cleaning Silvered Plated Lamp Reflectors
Never tried it but have heard "lamp black works".
Old 09-14-2020, 09:38 PM   #3
PalAl
PalAl's Avatar
Russ I am not familiar with this product, do you have a source or picture of "Lamp Black" what is this stuff?
Old 09-14-2020, 10:33 PM   #4
Bob Johnson
Bob Johnson's Avatar
Alternative method.
Get an aluminum pot big enough to hold the reflector. Fill it with water and several tablespoons of baking soda. Put the reflector in the pot and boil the water. There will be a chemical reaction between the aluminum and the silver sulfide. The reflector should be shiny again.
Bob
Bob Johnson is offline   Reply With Quote
Old 09-14-2020, 11:06 PM   #5
daveymc29
daveymc29's Avatar
So how long do I boil the soda water? Let it sit to cool or wash it off with cold water? Just trying to not overlook something and ruin what I have.
Thanks
daveymc29 is offline   Reply With Quote
Old 09-14-2020, 11:32 PM   #6
Ruth
It would be nice if you posted a link to this article so others don't have to search.
Ruth
Old 09-15-2020, 04:51 AM   #7
PalAl
PalAl's Avatar
You Sir are absolutely right!
I have thought the same thing many times after an exhausting search, my bad
Here is the link to the article
http://www.fordgarage.com/pages/reflectorcleaning.htm
Old 09-15-2020, 05:59 AM   #8
CA Victoria
CA Victoria's Avatar
My 2 cents:
I don’t doubt the process works but I can tell you that when I tried it I was not satisfied. The reflectors were not pristine to begin with but ended up un-usable. I take credit but I am not sure what I did wrong, it removed some of the tarnish but lost its luster.
I sent them to Craig Riker to be re silvered, he is very reasonable.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 09-15-2020, 07:11 AM   #9
Oldbluoval
Oldbluoval's Avatar
Did he actually resilver or chrome them? Big difference believe it or not
Yes Craig is reasonable but best of all very good! Best of two worlds!
Old 09-15-2020, 09:48 AM   #10
Badpuppy
Tried the boiling water & Al foil, didn't work well. Guess the water didn't stay hot enough.
Read online the jewelry buffs use salted lemon juice. Tried white vinegar & salt, tarnish wiped off easily with a soft cloth.
Old 09-15-2020, 09:53 AM   #11
Badpuppy
Lamp black/carbon black is basically plain old chimney soot. Pure carbon powder, probably sold by chemical suppliers.
Old 09-15-2020, 09:59 AM   #12
Jim M
Jim M's Avatar
Not sure what he used buy I sent him my light reflectors and they came back looking like they just came out of the factory. VERY satisified and a great gentleman. Had the good fortune to meet Craig at the fall sale in Harrisburg, PA.
Jim M is offline   Reply With Quote
Old 09-15-2020, 09:59 AM   #13
McMimmcs
McMimmcs's Avatar
Originally Posted by CA Victoria View Post
My 2 cents:
I also had unsatisfactory results. What was the cost of resilvering or should I buy new ones from Steve.
Old 09-15-2020, 10:44 AM   #14
chrs1961815
chrs1961815's Avatar
I believe a lot of the tarnishing comes from incorrect gaskets on the headlamp. The cork gasket should make it very hard to snap that ring in. It almost makes it like an air tight seal. If done right, you should not have to clean them for years.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-15-2020, 10:48 AM   #15
100IH
I think that you'd be lucky to find a reflector that no one has ever touched before you got there. The coatings are thin and won't stand any abrasive, or even a finger print.
100IH is offline   Reply With Quote
Old 09-15-2020, 01:22 PM   #16
PalAl
PalAl's Avatar
Ok.... The boiling water and aluminum foil scared me...
so here is what I did and it worked well for me
I used Tarn-X and then applied a coat of wax, so far it looks good
Hope it doesn't dissolve in a puff of smoke overnight
Old 09-15-2020, 01:31 PM   #17
Bob Johnson
Here is a picture of a headlight on a car that sat in a barn since the mid 1960s, over 50 years. The silver is still very shiny.
Bob
Old 09-15-2020, 07:18 PM   #18
shew01
shew01's Avatar
Here is a link.
https://www.etsy.com/listing/4748980...SABEgJh4_D_BwE
Old 09-15-2020, 09:40 PM   #19
PalAl
PalAl's Avatar
Thanks Shew01, another day of learning, this is used as a polishing compound I assume
Old 09-15-2020, 10:19 PM   #20
CWPASADENA
CWPASADENA's Avatar
I have my reflectors ready to be re-silvered and the shop I have used in the past is no longer in business. Could you post Craig Riker's contact information?
Thanks,
Chris W.
CWPASADENA is offline   Reply With Quote
