12-30-2015, 08:32 AM | #1 |
8rt bellhousing
This has been a bit confusing for me. I bought an 8rt to install in a '47 tonner. It came from a '49 f3. Unfortunately he had sold the cast iron belhousing on ebay. Hoping to be by his place today and buy the crash box 4 speed from the same truck. Will a stamped steel bh like one I have here work? The engine has an 11" clutch which I'd like to use. Also will need a starter. Will one from a 59ab work? I have lots of 59ab stuff. Thanks in advance. Heading over to the mainland today, wish me luck!
12-30-2015, 10:29 AM | #2 |
Re: 8rt bellhousing
And the starters are the same.
12-30-2015, 10:55 AM | #3 |
Re: 8rt bellhousing
An 11 inch clutch will not fit in the stamped steel 1/2 Merc bell housing. You need the cast iron 1/2 bell from a truck. Don't ask me how I know. There was one on EBay with the correct starter plate recently. Problem is shipping since they are heavy.
12-30-2015, 12:07 PM | #4 |
Re: 8rt bellhousing
I have what you need, but as noted shipping is probably not cheap.
12-30-2015, 12:34 PM | #5 | |
Re: 8rt bellhousing
I also have all the parts you need including a '48/'49 crusher box, with the granny gear, transmission, all removed from a '48 3/4 ton PU. ps...also have 11" clutch and pressure plate that may be usable as is, or definitely good cores for rebuild at Ft. Wayne.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 12-30-2015 at 12:43 PM. |
12-30-2015, 01:37 PM | #6 |
Re: 8rt bellhousing
There were some problems had to take some off the back of the flywheel and modify the starter drive--- but I didn't know that it wouldn't work-- drove it many miles and when sold it was driven to California |
12-31-2015, 02:06 PM | #7 |
Re: 8rt bellhousing
The one on ebay was likely the one from my engine. When I first saw it it was on the ground next to the 4 speed. I had gotten the cash limit from an atm when I saw the ad and I bought the engine, two 17" tonner wheels and some other goodies. He said the bh was on ebay at the time. I ran outa time yesterday to stop and buy the tranny. I didn't need it too bad, but it looked nice and I really love those 4 speed crushers. Thanks all for the info and generous offers! . I'll make a call about the cast bh. Do the hot rodder v8 guys use them or are they discarded like a lot of the other big truck gear? In other words is this considered a valuable piece in today's world?
12-31-2015, 03:12 PM | #8 |
Re: 8rt bellhousing
i have 3 cast ones, and no steel ones. sadly, i am 1500 miles away. want to trade? there are 2 different starter plates for these, one has a quite large opening around the rear main, for a truck pan? the other smaller one is merc . i only have the large hole plate. van pelts will show the plates, or some one here must know
12-31-2015, 08:00 PM | #9 | |
Re: 8rt bellhousing
12-31-2015, 08:53 PM | #10 | |
Re: 8rt bellhousing
12-31-2015, 09:19 PM | #11 | |
Re: 8rt bellhousing
01-01-2016, 01:43 PM | #12 |
Re: 8rt bellhousing
GB SISSON,
I believe the cast housing used on '48-'50 (?) trucks will work for all clutch configurations, however the correct starter plate must be used with each (cast iron or pressed steel). I have printed and attached descriptions of use to the appropriate pages of V8Bob's document showing all the bell housings, starter plates and oil pans used during the flathead era. see my PM. Howard |
01-01-2016, 09:47 PM | #13 | |
Re: 8rt bellhousing
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 01-01-2016 at 09:56 PM. |
01-01-2016, 11:59 PM | #14 |
Re: 8rt bellhousing
Thanks much! Just got back to my computer so will check this out in the morning.
01-02-2016, 02:15 AM | #15 |
Re: 8rt bellhousing
There is a bell housing now on the bay 171752567404 I see them often.
You could use a 10" pressure plate if your flywheel is 3 1/8" center to center they have 9 springs and if you are not hauling gravel should be good. Then get a disk 1 1/8" 10 spline . 9" no bolt to your flywheel. |
01-02-2016, 11:11 AM | #16 |
Re: 8rt bellhousing
going off the link that john put up, photos 1 and 2 of the truck bell and indented plate is what i have 3 of. scroll down to the photo with just starter plates, and put your cursor on the yellow note thingy, and it says the indented truck starter plate and the flat merc plate will interchange. thats what i have on a merc motor here i am using. cast bell, flat plate, missing the bracket to the pan, and no mount provision on the pan either, so somebody has been foolin with it.
01-02-2016, 08:30 PM | #17 |
Re: 8rt bellhousing
I did a bunch of hunting in my attic today. Found some interesting stuff .... I will post pics when I can, but the grandkids are here and other family due soon, so I need to concentrate on family stuff right now. Bummer. Down to the fact her grandkids are a bunch of fun!
01-03-2016, 12:23 PM | #18 |
Re: 8rt bellhousing
Well this is what I found... Looks like the engine with the 11" clutch still has it's starter plate. Should only need that cast BH. I have 2 stamped ones and my other 8ba needs a clutch, flywheel and bh. I found a 9" clutch and a flywheel that looks like it will accomodate the 9 incher. How can I tell if this wheel is correct for the 8ba and not from an earlier type. This engine is stuck and maybe today I will pull the heads and intake for a look-see. I have seen people in videos removing the head bolts with an impact wrench. Is this good practice?
01-03-2016, 12:41 PM | #19 |
Re: 8rt bellhousing
i do not understand why the starter plate leaning up against the tire has the big hole along the bottom? does the cut look home made? what does the back side of the one on the engine look like? flat, or with two indents ?
01-03-2016, 12:50 PM | #20 |
Re: 8rt bellhousing
Easiest way to separate the flywheels is to check if the boltholes for the clutch is through holes or bottom holes.
The back plate must have been modifed to accept the wrong flywheel... |
