01-30-2015, 09:57 PM | #1 |
1932 Wood Floor Pattern???
Does anybody have measurements for the roadster wood floor?
I have some plywood available through work that is very close in thickness. I would like to attempt the floor myself. It would seem the area around the pedals / column would be tricky to measure but would be critical for proper plate fitting. Roy Nacewicz makes great boards but our Canadian dollar just tanked so I would like to try this first. |
01-30-2015, 10:27 PM | #2 |
Re: 1932 Wood Floor Pattern???
The dimensions were in an issue of the V8 Times in about 1971 in case you have access to the back issues. I took a look at the number of mill cuts and decided to buy mine.
Charlie Stephens |
01-30-2015, 10:43 PM | #3 |
The top looks easy but the bottom is really complicated. I have built two sets using the V8 Times artical. I only have basic tools so it is a challenge to get all the reliefs cut. I extend the toe boards out to the cowl sides to seal this area. They are supposed to stop at the edge of the firewall. I also mask off and make seals from RTV to really try to seal it. The tape on the cowl keeps the RTV from sticking.
01-30-2015, 10:59 PM | #4 |
I have all the woodworking tools available to me through my work if I don't own them. If anybody has scanned the article "wink" I would love to look at it.
02-02-2015, 07:41 PM | #5 |
I would like to see this article as well.
Tim |
02-03-2015, 10:02 AM | #6 | |
I will also try to post them here as well. Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
