Old 09-04-2021, 05:55 PM   #1
34 fordor owner
34 fordor owner's Avatar
Default 1934 Ford Trouble Starting
Tried starting my 1934 Ford for the first time since renewing spark plug wires, spark plugs, and distributor. Every time it turned over it became closer to starting. It would sputter and sound like it wanted to start but would stop and the starter would still be engaged. Checked spark and there is spark to the plugs. And compression is good. Any ideas?
34 fordor owner is offline   Reply With Quote
Old 09-04-2021, 07:21 PM   #2
Robert/Texas
Robert/Texas's Avatar
Default Re: 1934 Ford Trouble Starting
I recently sent my distributor to Charlie Schwendler for repair. When I got it back, I installed it on my '34 roadster and it fired right up. The car idles and accelerates nicely.
Robert/Texas is offline   Reply With Quote
Old 09-04-2021, 08:15 PM   #3
VeryTangled
VeryTangled's Avatar
Originally Posted by 34 fordor owner View Post
Tried starting my 1934 Ford for the first time since renewing spark plug wires, spark plugs, and distributor. Any ideas?
Each plug wire will spark to ground with a nice snap?
-Jeff H
Old 09-04-2021, 09:30 PM   #4
petehoovie
petehoovie's Avatar
Check to be sure the wires from the plugs are going to to their matching numbers on inner distributor caps. - 1 to 1, 2 to 2, 3 to 3 etc.
Old 09-05-2021, 08:46 AM   #5
34 fordor owner
I checked the plugs and they do have a spark to a ground. I’m a little lost on possible things it could be.
Old 09-05-2021, 08:59 AM   #6
VeryTangled
Does bottle feeding fuel make any difference?
-Jeff H
Old 09-05-2021, 09:29 AM   #7
34 fordor owner
Doesl bottle feeding fuel make any difference?
Bottle feeding makes it sputter and almost start but never fully catches on.
Old 09-05-2021, 09:49 AM   #8
marko39
Sounds like timing is off.
marko39 is offline   Reply With Quote
Old 09-05-2021, 06:33 PM   #9
34 fordor owner
I am new to working on engines and learning as I go. How would I go about checking this?
Old 09-05-2021, 07:41 PM   #10
FlatheadTed
FlatheadTed's Avatar
Remove each wire set ,going by Petes diagram his view from the front Left ist is #one ,get a bulb or test light fix each HT wire in turn to a battery X or Neg run another wire from the Battery to a bulb touching the termanol on the cap appropriate to that # , it should light up ,check each one ,each cap will have two sets of numbers .Left set ,1234 ,corresponding to that spark plug ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 09-06-2021, 07:31 AM   #11
marko39
the best way is to have dist. set up on a machine. there are members of this forum who can do this for you.
Old 09-06-2021, 07:40 AM   #12
Terry,OH
Terry,OH's Avatar
Not sure if your reading posts from others but I would start as Pete suggest in posting #4 above. It is very easy to get plug wires out of place!
Old 09-07-2021, 07:38 PM   #13
34 fordor owner
When putting the inner caps in distributor do they need to follow the picture in post #4? For example when looking at the right side of plate does #1 slot need to go in the top left corner? Or does this not matter?
Old 09-07-2021, 07:56 PM   #14
koates
Forget that diagram as it can be confusing. Go by the actual plug lead numbers that are moulded into the bakelite caps. and you will be good to go. Regards, Kevin.
koates is offline   Reply With Quote
Old 09-07-2021, 08:45 PM   #15
Zeke3
Zeke3's Avatar
The inner cap has a tang that aligns with a notch in the distributor housing, this will line the caps up correctly for you then follow the numbers on the cap for the side of engine you are working on.
Zeke3 is offline   Reply With Quote
Old 09-07-2021, 10:06 PM   #16
VeryTangled
Just thinking about your situation.
It would be easy to 'ohm out' each wire, yes? Is a possible weak plug wire something you want to continue to fight or check off the list?
My mentor tried to teach me the wire to tip connector that goes into the cap should be meticuliously prepared. You need a good wire tip (solid core), and a solder joint to the clip that snaps into the inner cap, and no dull corrosion, just shiny bright bare metal with a "real" solder joint.
Wrestling the wires into the looms presents the possibility for poor connections or opens in the actual plug wires regardless of how good your ends are.
-Jeff H
Old 09-07-2021, 10:38 PM   #17
FlatheadTed
On a 3 bolt Coil type (1934 ) # one is at the rear bottom corner (7,30 ) from there its clock wise three (10-30 )two & four ,that as if you sitting in drivers seat ,The tang is at the rear,if fitting new wires I always scrape the corner of inside the cap using a bearing scraper ,
Old 09-09-2021, 07:05 PM   #18
34 fordor owner
Thank you to everyone for the help I plan on doing the things y’all have suggested for me this weekend. Another thing I was thinking is the carburetor has not been rebuilt and I do not know of the last time it was rebuilt if even ever. Could this play some sort of role in the car not starting? I know it will have to be rebuilt sooner or later because it is not taking in fuel from the fuel pump.
Old 09-09-2021, 11:48 PM   #19
FlatheadTed
Sorry ,The timing I gave is incorrect , its one three two four as Pete's Diagram clock wise ,from 10-30 number one .a 37 terminal cab in a 34 3 bolt gives a mis read .
