Old 03-18-2019, 02:49 PM   #1
deuce lover
deuce lover's Avatar
Arrow 33-34 hand crank bar length
Hopefully someone has an original to measure tip to tip .Cutting a '32 to lengthen for my '33.
deuce lover is offline   Reply With Quote
Old 03-18-2019, 03:18 PM   #2
34fordy
34fordy's Avatar
Default Re: 33-34 hand crank bar length
Mine is 17-3/4" or 45.084 cm
34fordy is offline   Reply With Quote
Old 03-19-2019, 03:32 PM   #3
deuce lover
Thanks.The rod I have is 16 1/8",so looks like I have to add 1 5/8".I will double check before I cut and weld.
Old 03-19-2019, 04:46 PM   #4
DavidG
DavidG's Avatar
Sheldon,
If your crank handle socket has a square opening, for a '33 passenger car the extension used (40-14070-B) was 17 1/4". The 17 3/4" version (40-14070-C) wasn't released until November, 1933 for Job #1, 1934 models.
Old 03-20-2019, 01:08 AM   #5
deuce lover
Thanks David.My handle does have the square opening.
