12-06-2018, 12:30 PM | #1 |
Identifying a model A frame
I know it's here, but I can't seem to find it. How can I tell a 28/29 frame from a30/31 frame? ...from the bare frame alone.
Thanks! |
12-06-2018, 12:56 PM | #2 |
Re: Identifying a model A frame
Check the serial number on the frame first, if there is one.
David Serrano |
12-06-2018, 01:02 PM | #3 |
12-07-2018, 09:28 AM | #4 |
Thank you!
12-07-2018, 11:59 AM | #5 | |
12-07-2018, 06:01 PM | #6 |
12-08-2018, 12:58 PM | #7 |
28/29 frames are drilled both sides for RHD and LHD for the steering box.30/31 frames are mostly drilled on one side depending whether the vehicle was built RHD or LHD .However there are 30/31 frames that are drilled both sides there is one under my P/U which also has the early handbrake cross shaft . This early 30/31 frame is in the minority and does come with the correct "low dip" rad mount area . If you see a frame which at first glance has only one steering box hole it is definately 30/31.
John in Suffolk County England. |
