11-21-2019, 09:29 AM | #1 |
Correct Head torque
IS my memory correct on 55lb's is the head nut torque for the flathead??? OR is it 65lbs (hence the reason for the post)
11-21-2019, 09:34 AM | #2 |
Re: Correct Head torque
I use 45 lb ft.
11-21-2019, 11:08 AM | #3 |
The 1935 to 48 MOTORS MANUAL says on page 437 the following:
cast iron heads 50 to60 ft.lbs, aluminum heads 35 to 40 ft. lbs. The 49-51 Mercury Manual says: 65-70 foot pounds. I would assume 49-53 Ford would be the same. |
11-21-2019, 11:12 AM | #4 |
I torque all my heads to 45 ft/lbs for 3 heat cycles Don't break and retorque. I use bolts most of the time and use a sealant on the threads.
11-21-2019, 02:50 PM | #5 |
The Truck manual for 48-52 8BA/8RT says to go 65-70. FelPro says the same for their PermaTorque gaskets.
'52 F-1, EAB flathead |
11-21-2019, 03:12 PM | #6 |
11-21-2019, 04:02 PM | #7 |
Thanks for everyone's input, I'll follow Flatjack9 & Ol Ron's input and do the 45 with the 3 heat cycles, its for just ONE nut as I removed to clean and lube the ground strap!!! Thanks again.
11-24-2019, 08:48 AM | #8 |
Not meaning to steal thread but recently installed the right bank head on an 8BA. Thought about the sealant hardening & Ole Ron’s instructions to torque then heat cycle 3 times & retorque. I used the Permatex w PFTE & couldn’t see any indication of whether it was the hardening type or not. If hardening type would retorque break water seals & torqued head bolt threads?w
Nomad |
11-24-2019, 09:19 AM | #9 |
I use 40 on 33-34 aluminum heads .
Had a weeping head gasket years ago and attempted to fix it by going to 60 . Got to remove the heads to replace some stripped studs . Won't do that again . |
11-24-2019, 10:14 AM | #10 |
What you used is non-hardening.
11-24-2019, 10:20 AM | #11 |
flatjack's correct...the sealer you used doesn't completely harden and will be fine for retorque. I use it every day (I rebuild diesel engines) for both oil and water thread sealing and it is very good. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
11-24-2019, 11:18 AM | #12 |
Thx Flatjack9 & Terry, again sorry to change direction of thread
Nomad |
11-24-2019, 01:28 PM | #13 |
The Nut's Behind the Wheel!
11-24-2019, 03:27 PM | #14 |
I’ve had a loose nut behind the controls for years, can’t figure out how to fix it,
Nomad Last edited by AnthonyG; 11-25-2019 at 10:32 AM. Reason: Fat fingers |
