11-18-2016, 06:26 PM | #1 |
Aluminum block almost finished.
Only a few more items to cut and then programming is proved out for the 1st machining OP.
Tod |
11-19-2016, 05:38 AM | #2 |
Re: Aluminum block almost finished.
Outstanding work Tod
11-19-2016, 06:23 AM | #3 |
Tod - sure looks like the real deal!! Thanks for your pioneering work on this. Are the bearing caps aluminum as well? Dave
11-19-2016, 06:48 AM | #4 |
11-19-2016, 09:11 AM | #5 |
Very Nice!
11-19-2016, 07:32 PM | #6 |
You're a talented & amazing Man, to be able to accomplish such amazing feats! Bill W.
11-19-2016, 09:03 PM | #7 |
11-20-2016, 07:53 AM | #8 |
11-20-2016, 10:17 AM | #9 |
Can you tell us how the casting was made and do the external features look exactly like an "A" engine? Did you modify the water cooling passages or are they the same as the orignals?
11-20-2016, 10:43 PM | #10 |
Do you plan to sleeve the cylinders ?
I would not gamble all that work on Al bearing caps . |
11-21-2016, 07:42 AM | #11 |
11-21-2016, 07:46 AM | #12 | |
Tod |
11-21-2016, 11:38 AM | #13 | |
I'm sure Tod's caps will be made from something close to 7075 T-6, and maybe even hard Anodized.. With Aluminum main caps and block,..you need to pay close attention to the main clearance,..it will change vs. Iron / Steel combinations.. |
11-21-2016, 12:40 PM | #14 | |
Tod |
11-21-2016, 01:13 PM | #15 | |
Alum main caps sound good when taken in contest with this information ! Do you anticipate stamping any ID numbers on the pad for the engine # , or do you leave that to the customer |
11-21-2016, 05:35 PM | #16 |
Today I totally finished all 1st OP A programming and machining. 1st OP B is next, which is the drilling of the 3 oil galleys that run from the 3 main journals to the main oil galley.
I left this block about .020 thick just in case I wanted to do any machining once it is out of the machine and also as a way to double check the full 4th B axis for accuracy as it repeatedly turned back and forth while I programmed and ran each tool over the last few weeks. Today I swapped pallets and brought it out for a "look see". I put the verneer calipers on it and from front to rear it is dead on parallel. .020 thick both ends. Tod |
11-21-2016, 06:29 PM | #17 |
11-21-2016, 06:38 PM | #18 |
11-22-2016, 07:47 AM | #19 |
Hi Tod, nice looking block, do you plan to use a cast iron head? 6:1 head ? Are the cam journals bushed? Are the head studs helicoiled in place? Thanks for your efforts, Barry B.
11-22-2016, 10:18 AM | #20 |
Great news! keep on pouring!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
