Old 08-02-2021, 03:46 PM   #1
waynet
Default 8BA Oil Pan Cleanout Plate-For trucks only?
1) Is the 8BA Oil Pan Cleanout Plate applicable only to Pickups and Trucks and what is the advantage?
2) Can we measure crank throw by removing Cleanout Plate rather than removing cylinder head?
As always thanks to you kind folks for any replies.
waynet is offline   Reply With Quote
Old 08-02-2021, 03:52 PM   #2
cas3
Default Re: 8BA Oil Pan Cleanout Plate-For trucks only?
The clean out lets you clean the oil pickup screen, and allows for more places to leak. I suppose if one was really ingenious you could figure out a way to measure stroke...some how.
Old 08-02-2021, 03:53 PM   #3
supereal
supereal's Avatar
The early Ford tractors also had a "clean out" panel on the oil pan.
supereal is offline   Reply With Quote
Old 08-02-2021, 04:38 PM   #4
51504bat
51504bat's Avatar
I use one on the 8ba in my '39 p/u for tie rod clearance.
Old 08-02-2021, 07:59 PM   #5
Ross F-1
Ross F-1's Avatar
The oil pickup dome takes up almost all the room above the plate. I don't know how you could really measure anything with confidence.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-03-2021, 08:23 AM   #6
1931 flamingo
1931 flamingo's Avatar
Crank throw: Remove a spark plug, insert a long cable tie, welding rod, etc, hand crank it over, measure.
Paul in CT
Old 08-03-2021, 03:34 PM   #7
waynet
Don't the spark plugs sit over the cylinder valves or is there enough room to insert a measuring stick?
Old 08-03-2021, 07:58 PM   #8
1948F-1Pickup
1948F-1Pickup's Avatar
Paul in CT
Yup. You won't be doing that with a flathead V8, removing a spark
plug doesn't get you a look at the piston top....
1948F-1Pickup is offline   Reply With Quote
Old 08-03-2021, 07:59 PM   #9
1948F-1Pickup
That's about the extent of it.
Old 08-03-2021, 08:21 PM   #10
tubman
tubman's Avatar
You can get a good measurement of the exhaust valve lift, though.
