Old 12-08-2016, 05:56 PM   #1
GasWorksGarage
Default 1929 Condenser
Why would anyone mount a condenser like this?
GasWorksGarage is offline   Reply With Quote
Old 12-08-2016, 06:21 PM   #2
700rpm
700rpm's Avatar
Default Re: 1929 Condenser
Keeps it cooler.
Ray Horton, Portland, OR
Old 12-08-2016, 07:10 PM   #3
tbirdtbird
look silly but what Ray said.
I had to do an emergency condenser change on a RR in the middle of a mall for a customer and I did just that for the sake of expediency since he was blocking the lane.
There are posters here, tho, that will tell you this will not work. Ask the RR owner if it works
'31 180A
tbirdtbird is offline   Reply With Quote
Old 12-08-2016, 07:25 PM   #4
Gold Digger
I mounted one like that after burning out 3 condensers in the distributer about 30 years ago and it's still there and still starts and runs good. The Autolite waffle stile heater even with a baffle in place didn't keep from melting the condensers. I've read on here that it's not good to run cars this way because of spark not being as good as condenser in the distributer, but if they want run where they're suppose be you got to do what you have to.
Gold Digger is offline   Reply With Quote
Old 12-08-2016, 08:36 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
It's that blue crimp terminal that bothers me.
Old 12-08-2016, 09:04 PM   #6
Special Coupe Frank
Special Coupe Frank's Avatar
VW used to mount the condenser external from the distributor with their air-cooled engines, if I recall...
Special Coupe Frank is offline   Reply With Quote
Old 12-08-2016, 09:59 PM   #7
Kevin in NJ
Yes it works, but...
The reason it is at the distributer is because the added distance away from the points adds resistance between the points and condensor. This allows for more voltage build up and arcing at the points which is what the condensor supposed to prevent. This means a better chance at shorter point life. There are some variables in the system from inductance and capacitance in the longer line. Basically some might work better then others.
Capacitors are tightly wrap tin foil with thin specially coated paper between. The old stuff dried out and did not like the heat. Today we have some capacitors that are happy with the temps and work fine last a long time. They probably cost $.10 more then the common stuff. So if you buy any (including the V8 type) new 'normal' condensor you might get some low bid made in china thing. Mustang people complain about the new name brand ones failing quick.
The secret is to buy the A&L burnout proof condensors and put them in (yes even if you have the V8 plate) and forget about them. Cheap, simple, reliable for years and years. Get a spare to fix the guy in your club too cheep to buy one so you dont have to stop on tour all the time.
Kevin in NJ is offline   Reply With Quote
Old 12-08-2016, 10:41 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A friend had his condenser mounted by the coil on a Toyota, kept burning up points! Moved it back to the distributor & problem SOLVED!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-09-2016, 01:19 AM   #9
jfreddie
Couldn't agree more with Kevin in NJ. The short proof condenser is the best answer...plainly identified by three spot weld points on the end. Can even use it with the modern points.
jfreddie is offline   Reply With Quote
Old 12-09-2016, 08:20 AM   #10
Big hammer
My A came with a condenser at the coil,why it was there for me? Because of the flat top ottwell heater you have to remove the manifolds to change the condenser or remove the distributor. I changed the condenser with the best one available at that time. I think it was called a burn proof condener, maybe an A&L? this was in the late 70's
Old 12-09-2016, 02:19 PM   #11
GasWorksGarage
I am going to put it back in the distributor and replace with a burn proof.
Old 12-09-2016, 03:06 PM   #12
700rpm
700rpm's Avatar
Good call.
Old 12-09-2016, 11:19 PM   #13
Flathead
Flathead's Avatar
The A & L condenser and V8 points has worked perfectly for me. A quality set of original points would be OK also. The A & L "burn-out proof" condenser can be trusted.
Flathead is offline   Reply With Quote
Old 12-10-2016, 04:25 PM   #14
mantta
mantta's Avatar
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
It was probably put in the distributer for theft protection. An external one would make hotwiring very easy.
mantta is offline   Reply With Quote
Old 12-10-2016, 05:25 PM   #15
Tom Wesenberg
When the condenser is moved to the coil, then if it happens to have a short (no matter how minor) it will drain the battery. Remember, the coil has voltage at all times, and the ignition switch ungrounds the points and connects to coil ground side, when it's switched ON.
Old 12-10-2016, 06:47 PM   #16
jfreddie
Good point!
Old 08-19-2019, 09:04 AM   #17
djuby1
A L burn proof condensor was mention in several replies. Where can these be found for purchase. Didn’t have any luck searching on the web for them.
djuby1 is offline   Reply With Quote
Old 08-19-2019, 09:22 AM   #18
ryanheacox
ryanheacox's Avatar
They don't have a website, just a phone number, (860) 693-0112. I think most of the vendors carry their condenser if it is advertised as burnout proof.
ryanheacox is offline   Reply With Quote
Old 08-19-2019, 04:27 PM   #19
john in illinois
john in illinois's Avatar
I did not know about use with modern points. Thanks.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-19-2019, 09:33 PM   #20
Purdy Swoft
Purdy Swoft's Avatar
I have run the condenser connected to the coil on one of my model A's for over twelve years with no problems . Anybody can believe whatever that they want . The cheap China made condenser that many model A venders sell won't last very long no matter where they are mounted . I learned about mounting the condenser in this manner fifty six years ago and it has worked well for me on several model A's
