06-08-2018, 04:07 PM | #1 |
1928 Model A Ford Roadster pickup V8 60 HP
City:
SAINT PAUL
State:
Minnesota
Price:
17,000
1928 Model A Ford Roadster Pickup V8 60 HP
Price reduced $ 16,000.00 Engine: 1938 "cast iron side" V8 60 HP. Complete rebuild with NOS pistons, rings, con rods, main & rod bearings, valve springs, keepers, camshaft gear, oil pump gears. Used camshaft, repro cam bearings, oil pickup tube and screen. Repro fuel pump, rebuilt starter and generator. Rebuilt "48" Stromberg. Crankshaft ground to .020/.020 Trany: Resufaced cup style flywheel. NOS Pressure plate, starter ring, clutch plate, throwout bearing and collar. Used small 60 HP trany case, shift tower and forks. The internals are NOS, gears, shafts, bearings and u-joint. Rear axle: Axle came out of a running and driving car, 4.11 ratio. Torque tube, radius rods and driveshaft shortened to fit the "A" frame. Rebuilt "A" shocks front & rear. New rear spring, 5 leafs. Rides nice.DSC00919 (300x169).jpg DSC00920 (300x169).jpg DSC00923 (300x169) (2).jpg DSC00924 (300x169).jpg Brakes: Drums front & rear reground within limits. New shoe arced to drums, repro wheel cyls. New 16 Firestone tires, new tubes. Body: No seat springs just foam, body is channeled 3". Repro windshield frame and new safety plate glass. Steering: Dropped Ford axle. Rebuilt "A steering gear, with new worm, sector and bushings. New front spring. Misc: 6 volt positive ground, horn and lights work. Master switch. I finished the pickup in 2008 and it has less than 2000 miles on it. Last edited by Gary in MN; 07-12-2018 at 07:15 AM. |
06-25-2018, 10:55 PM | #2 |
Re: 1928 Model A Ford Roadster pickup V8 60 HP
Price reduced to $ 16,500
06-30-2018, 06:52 PM | #3 |
btt
07-12-2018, 07:13 AM | #4 |
Price reduction $16,000
07-12-2018, 07:14 AM | #5 |
btt
07-23-2018, 09:37 AM | #6 |
08-03-2018, 07:23 AM | #7 |
btt
08-16-2018, 07:06 AM | #8 |
Price reduction. $ 15,000.00
09-07-2018, 10:06 PM | #9 |
btt
