06-24-2020, 11:20 AM | #1 |
No spark
1947 Ford deluxe v8. 12 volt. New battery, new pro billet distributor,rotor and cap with red wire to positive side of coil black wire to negative, new 1.5 ohm coil, new plug wires. Checked with test light 12 volts to coil. Checked plug wires with ohm meter for continuity because were new. Checked 3 different plugs for spark.Not using any of cars wiring, just a jumper wire to coil and a jumper to activate starter.And no spark, where do i start? Thanks
06-24-2020, 12:14 PM | #2 |
Re: No spark
I'm not familiar with a pro billet distributor. Are you saying there are two wires from the distributor that connect to the coil? Not sure I understand how that would work. Where are you connecting the battery power to?
06-24-2020, 12:29 PM | #3 |
Re: No spark
Is this similar to what you have?
06-24-2020, 04:04 PM | #4 |
Re: No spark
Yes that is the distributor i have. But i dont have the cdi box in the second picture. I have a normal 12 volt round coil with a + and - and a wire to the distributor cap. According to the instructions the 2 wires from the distributor; a red and black, go to + and - on coil. And i need 1 wire from battery to + on coil for power. It says i dont need resister ballast or cdi box if i use the 1.5 ohm coil
06-24-2020, 05:44 PM | #5 | |
Re: No spark
06-24-2020, 06:36 PM | #6 |
Re: No spark
1 6 the 1.5 ohm coil is for 8-cylinder engines with 12 volt system. they were designed for breakerless ignitions. 0 0 |
06-24-2020, 07:10 PM | #7 |
Re: No spark
Overall Height: 6.00"
Outside Diameter: 2.20" Cap Type: Socket / Female Cap Terminal Style: Socket / Female Maximum Voltage: 40,000 volts Turns Ratio: 115:1 Voltage: 12 volts Resistance: 1.5 ohms Secondary Resistance: 10.60 ohms Inductance: 6.40 Peak Current: 7.2 Spark Duration: 1.5 Material Type: Steel Finish: Chrome MFG. Part #: 40001 GTIN Code: 694342004859 Sold in Quantity: Each EO#: D-57-21 Info |
06-24-2020, 07:12 PM | #8 |
Re: No spark
That is the coil the company recommended i buy for that distributor ^
