Old 06-09-2020, 07:10 PM   #1
ZOLTAR
Send a message via Yahoo to ZOLTAR
Default Need electrical / ignition help
Still trying to get spark out of my 59 a b. I have a rebuilt distributor what seems to be a good coil. Just have it hot wired to the battery into the start of now. When I crank the motor I get no power to the coil when the motor isn't turning over I have power.. any suggestions? Thanks Rich 6 volt battery positive ground 1 wire to the coil ,,condenser?
ZOLTAR is offline   Reply With Quote
Old 06-09-2020, 07:22 PM   #2
Don
Don's Avatar
Default Re: Need electrical / ignition help
Sounds like low voltage!maybe starter drawing to much current,,,does it spin very fast??
DON P
Don is offline   Reply With Quote
Old 06-09-2020, 07:26 PM   #3
JSeery
JSeery's Avatar
Little bit hard to follow how you have this set up. Should be a wire to whatever you are using as a starter solenoid. The power wire from the battery would connect to a terminal on the solenoid, this same terminal would also connect to a switch (starter switch). The other terminal of the switch connects to the (-) terminal of the coil and the (+) terminal of the coil connects to the point/condenser. (No resistor is needed with 6v and a 1.5 ohm coil).
JSeery is online now   Reply With Quote
Old 06-09-2020, 07:28 PM   #4
ZOLTAR
it is a helmet distributor with coil on top of thatIt is a helmet distributor with coil on top of that I only have one wire hooked up to the coil am I doing something wrong. Thanks
Old 06-09-2020, 07:32 PM   #5
tubman
tubman's Avatar
Silly question. Do you have the condenser installed?
tubman is online now   Reply With Quote
Old 06-09-2020, 07:33 PM   #6
ZOLTAR
yes not silly
Old 06-09-2020, 07:36 PM   #7
JSeery
JSeery's Avatar
On the stock type coil on distributor there is only one wire to the distributor, the other connections are built into the distributor/coil. You only need the two wires with a separately mounted "can" type of coil. You do need the resistor in your case.
Old 06-09-2020, 07:38 PM   #8
ZOLTAR
Okay I'll take a moment and explain better thanks for your help. Have a 6 volt battery negative side going directly to starter. Coil connected to the same negative side of battery with an inline resistor. I take the positive side of the battery and ground it to the block that makes the engine spin takes away power from the coil. Not getting any spark to the wires. Engine is turning over fairly fast but not what I would consider full speed. Thanks for your help and patience
Old 06-09-2020, 07:39 PM   #9
ZOLTAR
thanks for that that's what I thought
Old 06-09-2020, 07:45 PM   #10
JSeery
JSeery's Avatar
Should work if you have enough battery power. If you have a volt meter connect it to the wire going to the coil and see what voltage you have when cranking the engine. You need 3.5 to 4 volts to get a good enough spark to fire the plugs. Just touching the positive to the engine for a ground may not be giving you a good enough connection for what you need. I would invest in a starter solenoid and a switch and use a good ground from the battery to the engine.
Old 06-09-2020, 09:07 PM   #11
ZOLTAR
Well somehow I managed to melt my coil maybe it's time for electronic ignition
Old 06-09-2020, 09:19 PM   #12
tubman
tubman's Avatar
I don't think that's a good idea. I think it would be best if you fully understand how the stock ignition works, with all of it's quirks and foibles. Get a basic understanding of how everything works.
Plus, it's a lot more expensive if you damage the electronic stuff.
Old 06-09-2020, 09:20 PM   #13
JSeery
JSeery's Avatar
Big jump based on wiring it up the way you did. The stock system is a strong reliable system. Electronic systems do work, but not well on 6v and much more sensitive to power issues.
Old 06-09-2020, 09:22 PM   #14
40cpe
40cpe's Avatar
With your setup when you take the positive off the block you remove the ground return for the ignition, too, so you wont have any voltage to the coil.
40cpe is offline   Reply With Quote
Old 06-09-2020, 10:44 PM   #15
ZOLTAR
thanks for your advice everybody
Old 06-09-2020, 11:30 PM   #16
Aarongriffey
Get another battery, set it on the ground by the front of the car .
Disconnect the wire from the coil.
Run two jumper wires from the second battery to the car, one ground and one to the coil. Now see if you get spark when cranking it over.
Aarongriffey is offline   Reply With Quote
Old 06-09-2020, 11:31 PM   #17
petehoovie
petehoovie's Avatar
Well somehow I managed to melt my coil.
Show us a picture of this melted coil....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 06-09-2020, 11:33 PM   #18
Aarongriffey
I had that same problem a week ago on a car that just had the engine rebuilt.
Turned out the rusty nut on the coil was not tight.
Old 06-10-2020, 04:12 AM   #19
koates
If you run your original ford coil on top of the distributor then you must use the original ford type resistor in the coil power feed wire. No resistor and you will cook the coil. These coils run on 4 volts , not 6 volts. Also if the ignition is turned on for a longer period without the engine running then its possible to cook the coil. Forget electronic ignition. That's the usual remark when owners of old Fords cant work out or fix the original system. The original Ford V8 ignition is an excellent system. Learn how it works. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-10-2020, 05:05 AM   #20
FortyNiner
FortyNiner's Avatar
So, does this mean you don't have a starter relay (a solenoid to some of us) in the circuit? Does your setup match the diagram in post #3 from JSeery?
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Thread Tools
Display Modes
