04-26-2020, 03:28 PM | #1 |
4:40.1 Gears in a 39 Sedan?
I was surprised to find 9/40 stamped in the rear of my 39 sedan which means it has 4:40 gears.
Any thoughts? Was that an option? More likely from a 60HP car? Thanks for any info. Chris |
04-26-2020, 03:40 PM | #2 |
Re: 4:40.1 Gears in a 39 Sedan?
4.44 was a 60hp ratio
Alan |
04-26-2020, 03:40 PM | #3 |
Was the car originally a V8-60?
40/9 - 4.44 Was that a V8-60 gearset? Either the axle has been swapped or the motor. Was 4.44 an option on the 39s for mountainous areas? |
04-26-2020, 03:46 PM | #4 |
The 9/40 stamped on the underside of banjo housing does not gaurentee you have 4:40:1 gears inside the housing. They were likely used with the smaller 60hp engine, but could have been changed out for another ratio if/when the 60hp was changed to a larger, higher hp FH engine.
You could remove the rear oil filler plug on the banjo housing and count teeth on ring gear to determine actual gear ratio.
04-26-2020, 03:51 PM | #5 |
Thanks for the info, it currently has a 8BA in it and I don’t know much about the car. It’s a standard so it’s very possible it was a 60HP car. What other indicators are there for a 60 hp car.
04-26-2020, 04:12 PM | #6 |
04-26-2020, 05:02 PM | #7 |
Didn't original V8-60 cars have tube front axles instead of I beam style ? Or wasn't that in '39 ?
Sal |
04-26-2020, 05:07 PM | #8 | |
Update: per Bruce Lancaster It was used in limited production (in the hundreds) at least 1938-40, mostly in 85's, according to the Ford production letters--see the '38-39 book from the V8 club, which contains production change orders. I assume the limited production release was just field testing of a possible alternate production method--"Well, it passed engineering, now let's see if the customers can break'em"... They were absolutely definitely used on 85's '38-39, from both Ford records and from production line pictures of cars with them. In 1940, leftover ones were supposedly used on the few '40 60's sold--undocumented but verified from cars. I have yet to see any mention of other use on 60's or any documentation of 1937 use, but all agree that surviving Ford records are nowhere near complete. All original pictures I have seen have been on 85's... From the numbers given in the surviving records, I would venture a flying guess that only a few hundred of the USA version actually ever existed--and I'd bet that most were grabbed from junkyards by sprint car and dragster builders long, long ago. It looks to me like the tube axle was never STANDARD for anything--it was released in very small batches mixed in with use of the regular forging. I think the letters say Rouge plant only, I guess keeping them close to Ford so engineers could check out use and problems easily. I think overseas, a slightly different version may have been used on Model 62 Fords, British-European only v860 cars. |
04-27-2020, 07:27 AM | #9 | |
Some 60hp car had tube axles, some did not. Even deluxe cars got the tube axle on occasion. I had one that was definitely factory installed in a '40 convertible.
04-27-2020, 10:30 AM | #10 |
Thanks for the clarification Jseery, Kube and Bruce. Good to hear the REAL info.
Sal |
04-27-2020, 12:57 PM | #11 | |
The serial number on a V8-60 car would begin with a "54" instead of the "18" you see on the full-size flathead cars during the four years that 60 horse engines were offered. It should be stamped into the frame rail as well as appear on title/paperwork. I own a tube axle that came out of a very original, low-mileage, single-family owned '39 Standard coupe with a V8-60. DD |
04-27-2020, 04:41 PM | #12 | |
04-27-2020, 05:24 PM | #13 | |
Bruce will always be remembered as an icon of old Ford knowledge.....and most-certainly a huge loss to our community in countless ways! DD |
04-27-2020, 05:26 PM | #14 |
Because of his many post and willingness to share his knowledge lives on.
