03-31-2020, 08:13 PM | #1 |
Best way to seal threads on indented firewall gas valve
I typically use teflon tape for this - is there a better way ??
Many thanks - JIm |
03-31-2020, 08:44 PM | #2 |
Re: Best way to seal threads on indented firewall gas valve
I use pipe dope. Plain bar soap stops gasoline leaks also.
03-31-2020, 08:46 PM | #3 |
My choice is Indian Shellac! Sold at NAPA.etc
www.whidbeymodelaclub.com |
03-31-2020, 08:50 PM | #4 |
Small amount of perma-tex 2 non hardening cleans up with isopopryl alcohol.
03-31-2020, 09:35 PM | #5 |
thanks to all for your responses !!
Jim |
03-31-2020, 09:37 PM | #6 |
04-01-2020, 07:15 AM | #7 |
I must be doing something wrong! I don't use any type of sealant on my late '31 roadster's gas valve or gas lines. And I don't have any leaks.....
Bob-A |
04-01-2020, 02:35 PM | #8 |
I use a product called fuel lube. It work to seal threaded joints in fuel systems and also lubricate fuel valves and petcocks. It is quite common in the aviation world.
Jim |
04-01-2020, 03:06 PM | #9 |
Permatex thread seal;(not a recommendation where to buy, can be gotten at most parts houses)
https://www.aircraftspruce.com/catal...hoCQ1YQAvD_BwE
04-01-2020, 03:33 PM | #10 |
I just removed a fitting from the bottom of gas tank that I installed 10 years ago with non-hardening Aviation Permatex. The fitting is submerged in auto fuel and alternatively Avgas. The Permatex was still pliable and I never had another leak around the threads.
04-01-2020, 10:13 PM | #11 |
Nothing is needed. The ferrule seals against the tapered part in the valve. Same as on the carb. Never used any sealer in 37 years of working on Model A Fords.
04-03-2020, 12:17 PM | #12 | |
You are correct, no sealer needed on the tubing ferrules.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
