08-03-2020, 04:48 PM | #1 |
front axle for 1934 Ford
Hello
I am wondering if there ever was somebody offering 2" dropped front axles? I know of the common 4" drop for the hot rod scene. Was an axle available that is not as radically dropped? I might be interested in a 2" drop. Thanks for any information. cheers, Harty |
08-03-2020, 05:03 PM | #2 |
Re: front axle for 1934 Ford
There are a couple of guys on the H.A.M.B. that drop axles, so I am sure they can drop one to your specifications. "Okie Joe" is one of them, but I don't remember the others.
Best check over there for "Hot Rod" stuff. |
08-03-2020, 05:51 PM | #3 |
Anson Axles in CA. The best.
08-03-2020, 06:18 PM | #4 |
Hi; I understand that the Model A axle is the 'Zero' drop standard, and that the stock V8 axle is a 2" drop from that 'Zero'. Then a 4" drop would be an additional 2" drop of a stock V8 axle. Or 4" from a Model A of 'Zero'. Newc
08-03-2020, 06:23 PM | #5 |
Chiming in with Newc... Be careful with the terminology... 4-in drop does not usually mean 4-in from stock. It means 4-in total, or, around 2-in from stock. In any event, please check it out. I think your asking for 2-in from stock, meaning a 4-in axle ??? opinion.
08-03-2020, 08:37 PM | #6 |
08-03-2020, 11:18 PM | #7 |
so maybe a 1" drop below standard
08-04-2020, 12:21 PM | #8 |
That would be a 3 inch dropped axle. I would check with Oki Joe and see what he can do.
http://www.joesspeedshop.com/joesproducts.htm Nice guy, I like to drop by and talk with him. |
08-04-2020, 04:45 PM | #9 |
Vincent, Are you still running rod brakes on your car?
08-05-2020, 12:12 AM | #10 |
