08-14-2015, 08:32 AM | #1 |
Slant window kick panels.
I purchased a set of kick panels for a 31 slant window sedan I owned a few years ago but never got around to putting them in. I sold it to purchase a 31 Victoria and was told they would fit but again never got around to putting them in. Fast forward to now, I sold the Victoria to purchase a slant window cabriolet. I assume that they will fit? Would like some input before I pull it apart tomorrow.
Thx! |
08-14-2015, 09:15 AM | #2 |
Re: Slant window kick panels.
I have a Victoria and I just put cowl kick panels into it last evening. From what I can see, the kick panels are the same shape for all slant windshield cowls.
This is conjecture. I see no reason that the 1930-'31 cowl kick panels would be different regardless of a straight or slant windshield. My reasoning is that the kick panels interface with the gas tank, the cowl sides, the cowl floor rails and the "A" Pillars which appear to have the same shapes in 1930-'31 closed cars. The vacuum line to the windshield wiper in the passenger's side of the cowl is the only potential interference problem. The kick panels mount to the "A" Pillars with 4 fasteners on each. Starting at the bottom, the first 3 fasteners consist of a cup washer and an oval head sheet metal screw with coarse threads. The top fastener is common to the belt rail garnish molding, and it is a 12-24 machine screw going into a fixed nut in the cowl. I used all stainless steel hardware. The interface of the gas tank and cowl is a potential leak site, so it's a good idea to attach plastic sheeting to the backsides of the cowl kick panels. Leave the bottom edge open to avoid condensation. I use plastic garbage bags and spray adhesive for this purpose. I hope this helps you.
Bob Bidonde |
08-14-2015, 11:49 AM | #3 |
Thanks Bob!
08-14-2015, 12:06 PM | #4 |
my slant window town sedan has 6 s.m. screws and cupwashers as has others I've seen . Perhaps there were variations? Also, the metal receiver tab at the bottom edge of the panel is painted body color
08-14-2015, 05:42 PM | #5 |
Well........ I went over to the shop and got the new kick panels I bought from Lebaron Bonney. Box says 30-31 Victoria, on the back of the panels it says 30-31 slant window town sedan. Guess what, they don't fit the 31 cabriolet. Go figure. Could be modified to fit....... Bummer.
08-15-2015, 09:31 AM | #6 |
08-21-2015, 11:08 AM | #7 |
I saw that you are selling these kick panels. How did they not fit in the 68C? I may be potentially interested in them.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
