Old 04-13-2020, 05:38 PM   #21
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 351c miss/backfire under load?
"And we buy foods, food additives and pharmaceuticals from them?"
Not to mention cell phones and other electronics into which they insert spyware. Also aircraft parts.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 04-13-2020, 08:19 PM   #22
scicala
scicala's Avatar
Personally, I feel more comfortable with and prefer just using points and a condenser. Good quality points and condenser that is.
Sal
Old 04-15-2020, 08:33 PM   #23
cousinjd
So what 's the verdict guys? Any improvement in the drivability? Did any of the suggestions help? I noticed several sources on e-b advertising the distributers mentioned in original post.
cousinjd is offline   Reply With Quote
Old 04-15-2020, 10:10 PM   #24
craig
See if you can beg, borrow or steal an original Ford point distributor, with an original set of points and condenser and give it a try. I have attempted to use the same distributor you have and fought it right to the trash can. I'm surprised you had a total of 38 degrees of advance. Most of these things have springs so stiff that you'd have to turn 10 grand to get any advance. Are you sure you are not getting this advance with the vacuum only? Set your base timing between 10 and 12 degrees, disconnect the vacuum line to the dist., and see what you get for a total and how fast you get it.
You mentioned you had a little over 13 volts to the coil, running. It should be fine, but most 12 volt systems are producing a little over 14 volts when running. You cannot run a ballast resistor with this distributor unless it clearly states otherwise in the instructions. I don't think you have a jetting problem, but I agree with Bill, you don't need a 750 cfm carb. Ford made the original 4V Cleveland run very well with a 600 cfm
craig is offline   Reply With Quote
Old 04-16-2020, 07:13 AM   #25
Ford blue blood
Ford blue blood's Avatar
I had a problem with the 351C in my Ranchero. It started and ran for two 20 minute cam break-in runs and didn't hit a lick for over two weeks thrashing around on it. Finally got down to the ignition after thorough mechanical checks. New rotor, new cap and a new coil, no joy. Had a brand new rebuilt distributor so I figured the points were good. Well you know about "assume", put in a good set of USA made points and it hasn't missed a lick since. I do not trust the Chicom crap one second!
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 04-16-2020, 08:20 AM   #26
KULTULZ
KULTULZ's Avatar
Post Re: 351c miss/backfire under load?
The OP never got back. I may have p!ssed him off about a CHI-COM quality part.
I have been researching aftermarket electronic ignition regarding a topic in another forum and I couldn't believe (that's a lie) some of the crap that is actually going on.
And they keep buying it.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-16-2020, 01:10 PM   #27
40cpe
40cpe's Avatar
Not trying to pick an argument, but the OP very well could have been been acknowledging the distributor as being low quality by saying "China quality product" instead of "quality China product". Sometimes it is what we read into a printed statement.
40cpe is offline   Reply With Quote
Old 04-16-2020, 03:34 PM   #28
KULTULZ
KULTULZ's Avatar
If that is (was) the case, he should have canned it.
- WHY IS IT ... -
Old 04-18-2020, 06:00 PM   #29
39deluxecp
39deluxecp's Avatar
Sorry for the delay. Been too cold to mess with the car.tbe distributor is a cheep $50.00 self contained with the module in the distributor.i have checked and re checked float level, timing, vacuum leaks, fuel pressure, mechanical advance, sparkplugs.each ofthe corner sparkplugs, number 1,4,5,8, were covered by black soot The rest were tan like they should be. In. The intake manifold, number 1,4,5,8 are on the top level of the runner, and the rest are on the lower level. The manifold has no. Brand or part numbers on it. It is very poor casting quality and the runners are all different sizes. I know it's a y shot, but I think the problem is the intake. So I found a Edelbrock 2v, 180* intake. The one on it now is a 360*. Thanks for the help. Not much fun driving it and can't even burn the tires
39deluxecp is offline   Reply With Quote
Old 04-18-2020, 06:55 PM   #30
KULTULZ
KULTULZ's Avatar
Talking Re: 351c miss/backfire under load?
You must do a lot of bargain basement shopping ...
Is your CLV 2V or 4V cyl heads? You need to find at the least a used dist that you can convert to electronic.
- WHY IS IT ... -
Old 04-18-2020, 08:19 PM   #31
39deluxecp
39deluxecp's Avatar
Keeps me out of the bars!!!
Old 04-19-2020, 03:36 AM   #32
KULTULZ
KULTULZ's Avatar
You need to get her running again so you can get to the bars.
American grain farmers are depending on you ...
- WHY IS IT ... -
Old 04-19-2020, 08:41 AM   #33
Ford blue blood
I would get out there and look for a DuraSpark distributor and module. The unit in my street rod has been there since 1980 and never missed a lick. The stuff in the back has run out of it and it is still ticking along. (I do have a spare in the car)
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 04-19-2020, 09:50 AM   #34
39deluxecp
39deluxecp's Avatar
I have used this distributor before and it worked fine. If I had another distributor I would try it.i do believe it is ignition.buying all new duraspark components runs into a few bucks to. I have had good luck with those also. I will keo you posted
Old 04-30-2020, 03:12 PM   #35
39deluxecp
39deluxecp's Avatar
Just wanted to give an update. I replaced the sparkplugs with autolite 26 , which is 2 heat ranges hotter than the 24 that were in it. Ran much better, but it is still cutting out at higher load and higher rpm.tomorrow I will put the timing lite on it and check out the total advance
Old 05-01-2020, 03:19 PM   #36
39deluxecp
39deluxecp's Avatar
E85 to the rescue!!! after a new 180* edelbrock manifold, bigger (92) jets in the primary and secondary , new autolite 26 plugs, various timing adjustments, I put in a half tank of good old E85 to the 5 gallons already in the tank. It runs like a cleveland should now!. damn co-op gas anyhow. I am leaving the 92 jets in and running half unleaded gas and half E85. Thanks for all the help.
Old 05-01-2020, 03:51 PM   #37
50fordcoupeman
50fordcoupeman's Avatar
I run non-ethanol in everything I own that has a carburetor on it..........
50fordcoupeman is offline   Reply With Quote
Old 05-01-2020, 07:27 PM   #38
40cpe
40cpe's Avatar
Good old E85? I don't think I've heard that before.
Isn't all automotive gasoline unleaded now?
Old 05-01-2020, 08:15 PM   #39
Dobie Gillis
E85 is 85% ethanol and higher octane (100 to 105) than E10. Tuners are fond of it for the octane.
Old 05-06-2020, 06:45 PM   #40
39deluxecp
39deluxecp's Avatar
I ty it was stale gas.
