Old 01-16-2022, 12:59 PM   #1
Habusailor
Habusailor's Avatar
Default 28 wheels
What size model A rims fit on a 28 chassis? I have 18s all around now and would like larger on the rear and smaller on the front for my build
Habusailor is offline   Reply With Quote
Old 01-16-2022, 01:30 PM   #2
LeonardS
Default Re: 28 wheels
Model A rims were 21” for 1928/29 and 19” for 1930/31.
LeonardS is offline   Reply With Quote
Old 01-16-2022, 01:40 PM   #3
ronn
18s were 32 only..............
Old 01-16-2022, 02:42 PM   #4
nkaminar
nkaminar's Avatar
Lots of people run 16 inch rims and put larger tires on the rear and smaller tires on the front. If you do that check the alignment in the front.
Old 01-16-2022, 02:47 PM   #5
Eccentric Old Guy
Eccentric Old Guy's Avatar
What is the purpose for the two sizes of tires?
eog
Eccentric Old Guy is offline   Reply With Quote
Old 01-16-2022, 04:59 PM   #6
Habusailor
Habusailor's Avatar
2 sizes for looks, it’s a matchup of cab, box which has been shortened and 60 hp v8. Rat Rod
Old 01-17-2022, 11:58 AM   #7
rotorwrench
rotorwrench's Avatar
It's not too practical to carry two spares. Folks that do big and little tires generally just use the narrow low aspect ratio tires on the front and fat high aspect ratio tires on the rear. A person has to use wheels that will work for the hubs but most 5.5 by 5 bolt pattern Ford wheels will fit. If you want different size wires then use 1935 16" wheels on the front and keep the 18" on the back but you'll have to suffer for a correct spare.
Old 01-17-2022, 12:28 PM   #8
Jim M
Jim M's Avatar
Guess it's different strokes for different folks, but I prefer to leave it alone the way Henry made it. Not too many things in today's world that was made 90+ years ago and still working��
Jim M is offline   Reply With Quote
