10-13-2020, 07:25 PM | #1 |
Question on power to the light / horn switch
Is there only one hot wire that supplies power to the light switch and horn? My lights have gotten a little dim and my horn is not working correctly. Car starts fine and the battery is staying charged just fine. Am wondering if maybe there is an issue with the wire / wires that bring power to the switch on the bottom of the steering column. Thanks
10-13-2020, 08:46 PM | #2 |
Re: Question on power to the light / horn switch
Lights and Horn are powered slightly differently.
Lights are powered from the light switch at the bottom of the steering column, and are grounded at the lamp. The horn is powered directly, and is grounded via the center contact on the light switch, up through the steering column, at the horn button. Both lights and horn, however, are connected to the generator cutout terminal as their "source" If both lights and horn are struggling check your battery connections, especially the ground strap. Check the connections at the starter switch, terminal box, ammeter, and at the generator cutout. Look at this wiring diagram and follow it along |
10-14-2020, 07:34 AM | #3 |
And check your ground from the headlight bar to the frame. The normal path for grounding is all done with likely "fresh painted" connections, i.e. probably a "challenged" connection.
Many restorers after laboriously making sure everything is painted for preservation find issues with various ground paths throughout the vehicle. Starter is another one of these. It may be worth your while to run ANOTHER ground from say the headlamp reflector shells and horn motor field bolts down to the frame of the car. Joe K
Shudda kept the horse. |
10-14-2020, 08:37 AM | #4 |
I ran a ground wire between the light conduit to the forward hood latch screw on each side. Attach tinned wire end to conduit with a hose clamp, #10 lug on the frame. Eliminates problematic connections through bar and fenders. I added a horn relay and ran its ground wire through the horn conduit to the same point on the frame.
10-14-2020, 08:46 AM | #5 |
There should be 2 wires going from cutout to light switch, one for lighting, one for horn---
10-14-2020, 10:09 AM | #6 | |
JayJay |
10-14-2020, 10:40 AM | #7 |
You might have the same harness as me. I have one black wire that feeds the lights and horn off the generator. It must be spliced into the horn and light switch feed wires in the main loom. Can't think of any other way it would be done.
10-14-2020, 01:58 PM | #8 | |
I'm curious, where does the pwer to the lights come from?
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 10-14-2020 at 02:09 PM. |
10-15-2020, 10:02 AM | #9 |
Thanks everyone. I found a cobbled job inside my horn. The wires were just stuffed into the connectors. I have installed new connectors and mounting blocks in the horn and am waiting on some new ends for the two horn wires. I also took my light switch apart and cleaned it with electric contact cleaner. This seemed to help the light some. I will experiment with an additional ground wire to see if that helps even further. Thanks again
