05-27-2019, 11:51 PM | #1 |
tool help
Would any one have a KR wilson or similar tool that you use to get the driveshaft bearing sleave out.
I need the outside diameter of it so I can make one. thanks Lawrie |
05-28-2019, 12:58 AM | #2 |
Re: tool help
Which bearing sleeve - front or centre?
05-28-2019, 01:36 AM | #3 |
Re: tool help
Brian ,the front roller bearing sleave next to the speedo drive.
Lawrie |
05-28-2019, 01:43 AM | #4 |
Re: tool help
Lawrie, I cut the front of a torque tube off in order to measure that when I made a puller a while back. I still have it at work, I'll measure up and post the information tomorrow after I get home from my hard day of toil. Brian
05-28-2019, 01:47 AM | #5 |
Re: tool help
Lawrie I saw a post or maybe a video on youtube where someone made their own tool. It did not look too hard to make, just a piece of tube with a short piece of rod sticking out at a slight angle, filed to shape.
This is the one I was thinking of: https://youtu.be/LXLmcLBMa2A Mart. |
05-28-2019, 02:32 AM | #6 |
Re: tool help
05-28-2019, 08:10 AM | #7 |
Re: tool help
The diameter of the flipper on the end of the shaft is 1 9/16". Not sure if this is the measurement you need but it would be the most important. This is off a KRW puller.
05-31-2019, 07:44 AM | #8 |
Re: tool help
I made one out of PVC and a brass screw. Cheap and easy to make and easy to use. That sleeve just 'snaps" in place and is not a tight fit. Next to last photos shows simple slide hammer with washers to remove old OEM seal. Wish you lived closer so I could send tool to you.
I saw that video mentioned above and decided PVC would work. That sleeve is not a tight fit at all as the sleeve is slotted and flexible. Last edited by 19Fordy; 05-31-2019 at 08:40 AM. |
05-31-2019, 10:18 AM | #9 |
Re: tool help
Kurt I saw your video several years ago and made the tool. Thanks for sharing.
John
Welcome each day |
