04-22-2013, 08:39 PM | #1 |
Motometer question
I can't figure out how the Motometer is supposed to work. My overflow tube terminates in the radiator neck about 1/2 inch from the bottom of the neck. It looks like the Motometer "button" is about 3/4" above that.
It seems to me that it would only measure water temperature if it is expanding faster that it was overflowing.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
04-22-2013, 08:46 PM | #2 |
Re: Motometer question
think of it as a thermometer mounted on the window of your house. it does not need to be submerged to read the temp.
04-22-2013, 08:56 PM | #3 |
Mine worked well, even though it wasn't submerged. Water really churns around there when reved up, rev it up & observe!! Also, when cruising steady & you see the Moto-Meter go up & down in regular cycles, like maybe every 2 or 3 minutes, YOU ARE LOW ON WATER!!!!!
If your little red line ever gets "broken" or separated apart, don't panic, partly cover your radiator until lower RED touches the upper RED & they'll "HOOK" up & be one RED again. One guy swung it around on a rope to try to get the REDS together again & whacked the QUAIL Moto-Meter on his bumper & BROKE IT +*#@%@_+*%#$ Who says, Model A's can't be FUN? Look up "FUN" in your "BIG" dictionary! Bill W.
04-22-2013, 09:13 PM | #4 |
They read steam temp not the water temp
04-22-2013, 09:28 PM | #5 |
Ok, thanks for the replies, that makes sense. I appreciate everyone helping out the new Kid on the block..
04-22-2013, 11:03 PM | #6 |
04-23-2013, 12:13 AM | #7 |
Ray, Chief always said, "We are all CHILDREN, in oooooold skins"!! Bill W.
04-23-2013, 05:24 AM | #8 |
I learned something too. I didn't think about the temp probe being above the overflow tube......
And I didn't know that they only told you the temp once the water turned to steam......
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
04-23-2013, 08:00 AM | #9 |
How do you turn the tube in a motor meter (not a quail) Mine reads form the passenger seat
04-23-2013, 10:58 AM | #10 |
With your little HOT hands & a DOG Bone Wrench Buster T.
04-23-2013, 11:00 AM | #11 |
That one I know, just loosen the nut under the cap and turn it.
