04-22-2013, 09:57 AM | #1 |
How to remove bonded brake linings
Does anyone have a good method of removing bonded brake linings from brake shoes? I suspect heat would work, but if there is an easier way, I would like to hear about it. The linings are really bonded tight to the shoes. Thanks for any help.
Rusty Nelson |
04-22-2013, 10:24 AM | #2 |
Re: How to remove bonded brake linings
When I let a couple older cars just set for a year or two I found the bonded linings had come loose on their own.
04-22-2013, 10:44 AM | #3 |
I "think" the pros used some sort of oven?? Would a self cleaning oven remove them?? (I do live alone!) Bill W.
04-22-2013, 10:57 AM | #4 |
That is an idea Bill....I wonder what temperature they bond at?
How hot does the "self cleaning" get too? The big question for Rusty is...will Diane let Rusty do this? LOL The smell ? When I was heating the Aluminum heads in the oven too change the valve guides(at home), Helen wasn't too thrilled! The joint smelled! |
04-22-2013, 12:33 PM | #5 | |
04-22-2013, 12:39 PM | #6 |
Rusty |
04-22-2013, 01:14 PM | #7 |
We used a torch to heat them up, it worked pretty well but took some chipping to get them all cleaned off.
04-22-2013, 03:21 PM | #8 |
Better to put them in a old gas grill and burn them outside they smell bad real bad your house will smell and your wife will not be happy
04-22-2013, 03:50 PM | #9 |
My outdoor grill, where I do ribs, steaks, chicken and brats??? OH NO!! Those old brake shoes go in the kitchen oven, where they belong.
04-22-2013, 05:25 PM | #10 |
If you use a torch, I would assume you would heat the metal on the shoes behind the lining - correct? It would seem if you heated the linings, it wouldn't do much to loosen them from the shoes. Since my wife is now off on her week long trip to Portland, there will be plenty of time to air the house out if the lining smell when they are heated. I just hope I don't mess up the oven, she would probably notice that.
Rusty |
04-22-2013, 05:32 PM | #11 |
I wonder if an induction heater would work. I have seen them in "hot plate" configuration, and the temp setting goes up to 450-degrees. The plate actually does not get hot, but the part does.
Just a thought. Ron/IA
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
04-22-2013, 11:52 PM | #12 |
Years ago,I worked in a shop that bonded there own brake shoes.I would heat up the back of the shoe with the oxy-acet torch until the lining fell off.It does make a big stink!To bond the new linings I would take a thin metal around the pair of shoes after the bonding glue had been applied to them & tighten to the band with a turn buckle then they were put in a special oven to be bonded.
04-23-2013, 12:32 AM | #13 | |
04-23-2013, 07:37 AM | #14 |
Well, I found that putting them in the oven doesn't work. I put them in the oven for 2 hours and all I got was a bad smell. I cranked up the temperature to 550, but nothing happened (except the bad smell). I have a week for the smell to dissipate before my wife returns from her trip. I can still smell it this morning. I ended up cutting the lining off with my bandsaw. There is a little of the lining left on the shoes, but not much. I hope to sandblast it off if the snow ever goes away. We got 5 more inches last night here in the Twin Cities. Will it ever end!!!
Rusty Nelson Last edited by wrndln; 04-23-2013 at 10:07 AM. |
04-23-2013, 10:04 AM | #15 |
Well....this stinks.
Time to open all the windows and air the place out...maybe Bill can come and help you clean up. Weather report...5" of snow in Minnesota(global warming?).....California, we turned on the "swampers" at work yesterday..89 degrees. |
