04-25-2022, 08:13 AM | #1 |
Another gas gauge install question. Spinning as I tighten it
Hi All:
I went to snug up the gas gauge and the gauge itself is spinning as I try to snug up in the inner nut. I fooled with for about an hour and couldn't get it not to do that. Any thoughts as to what I'm doing wrong or how to stop it from spinning? Thanks, Tim |
04-25-2022, 08:32 AM | #2 |
Re: Another gas gauge install question. Spinning as I tighten it
Tim,
Are you using the proper tools to tighten it up? https://www.snydersantiqueauto.com/p...9367&cat=41753
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
04-25-2022, 08:51 AM | #3 |
04-25-2022, 09:07 AM | #4 |
You need two metal slip ring gaskets with a drop of oil between them. that will do the trick.
04-25-2022, 09:10 AM | #5 |
04-25-2022, 05:59 PM | #6 |
