Old 08-23-2017, 10:02 AM   #1
jwilliams81
jwilliams81's Avatar
Default Shock needle valve removal
I have a 31' town sedan. I noticed the other night that they are dripping from the needle valves.
I have been searching and reading. I would like to try and fill them to see if they are working at all before I pull them off the car this winter.
How are the needle valves sealed? is it an o-ring that I could just replace?
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 08-23-2017, 12:59 PM   #2
100IH
Default Re: Shock needle valve removal
As I recall there is a graphite string packing. It is possible different gasket makers and suppliers have tried different things over the years, try snugging the nut below the pointer. Careful, they tend to break, if its frozen -leave it. Any wobble in the shafts in the center of the cover, if so not good.
100IH is offline   Reply With Quote
Old 08-23-2017, 01:10 PM   #3
Oldbluoval
Oldbluoval's Avatar
I have used o-rings...you may have to stack a couple. Also, plumbers teflon string backing (not tape) will work. It's just tough to get those boogers to not leak. Usually around the cover however.
Oldbluoval is offline   Reply With Quote
Old 08-23-2017, 01:47 PM   #4
jwilliams81
Thanks for the input. I haven't touched the shocks since I bought the car. But I have been noticing drip marks on the garage at 3 of the four corners. I was under the car last night and noticed one of the front ones was leaking from around the needle.
I haven't tightened any of them yet.
I was going to tighten and fill them to see what happens.
Cincinnati, Ohio
Old 08-23-2017, 02:05 PM   #5
100IH
If the shafts are not wobbly, Next try to figure out what the fluid is. It could easily be a mix of stuff, sometimes things that are not compatible. Ford even changed the fluid more than a few times during the V8 years. At this point, motor oil will do to see the leaks. It won't hurt anything. If they hold OK, you have won the lottery. They still need to be rebuilt by one of the experts.
Old 08-23-2017, 03:43 PM   #6
jwilliams81
I am going pull the fill plug and use a vacuum to suck out anything that's in there.
I was going to try and refill with 100% glycerin
Cincinnati, Ohio
