Old 01-09-2011, 01:43 PM   #1
Charles Reese
Charles Reese's Avatar
Default Open Vehicle Body Socket
Not content after installing reproduction body sockets. Destroyed one (do not recall the vendor as they were ordered early in restoration) and the outer lip of the others do not lie flat against the sheet metal.
Suspect finding 8 originals is out of the question so am inquiring about anyone’s experience with Bratton’s #28880 body socket? Catalog states “new tooling much better quality than in the past”. Mac’s (A81002) seems to be a similar item but a bit less expensive.
Thanks, as always!
Charles Reese is offline   Reply With Quote
Old 01-09-2011, 02:54 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Open Vehicle Body Socket
I've been purchasing from Bratton's for a long time and know they usually try to stock the best available restoration repro parts for the old As. That doesn't mean they have a different product than everyone else is selling though. I would like to hear some experienced input on this as well since I will be needing to install some in a 29 roadster project soon.
Kerby
Back to the top.
Old 01-09-2011, 04:02 PM   #3
HoarseWhisperer
HoarseWhisperer's Avatar
I had so many cheap repro sockets that blew up and fell apart.
Used a washer to tap the crimping on the back-side and still had trouble with them.
Did find a quality set from a vendor in French Lick (MARC Meet), but cannot recall who it was.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 01-09-2011, 04:24 PM   #4
Ron Geer
Chuck - Try Lebaron Bonney for body sockets. Ron.
Ron Geer is offline   Reply With Quote
Old 01-09-2011, 05:04 PM   #5
peters180a/170b
peters180a/170b's Avatar
A+L Parts had a supply of N.O.S. original nickel plated sockets.. He had them on ebay a couple of times . Their price was a set for roadster was $39.00 ...[Deluxe Phaetons had 2 more then roadster] .Don't know if they have anymore . ?? Before Al died he was looking on making them better then whats out there.
peters180a/170b is offline   Reply With Quote
Old 01-09-2011, 05:15 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, A&L definitely has the best ones out there right now.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-09-2011, 05:27 PM   #7
jimvette59
jimvette59's Avatar
Has any body looked into www.RestorationStuff.com It has a lot of hard to find items. Check it out.
jimvette59 is offline   Reply With Quote
Old 01-09-2011, 09:44 PM   #8
wardkew
wardkew's Avatar
I got mine from Lebaron Bonney and have no complaints.
wardkew is offline   Reply With Quote
Old 01-09-2011, 11:12 PM   #9
Ron in Quincy
Ron in Quincy's Avatar
Original sockets were made out of brass and nickled plated. Some of the replacement are made of stainless; trying to set these in the body, due to their hardness, its difficult to up set the crimped end which locks the socket in the hole. I've tried using a wood dowel and a metal punch; you almost dent the area trying to up set the crimp.
I gave up and had some originals nickled plated.
Ron
Ron in Quincy is offline   Reply With Quote
Old 01-10-2011, 08:35 AM   #10
Charles Reese
hints on how to remove the poor fitting repros w/o 'spinning' and destroying paint?
Old 01-10-2011, 07:04 PM   #11
Larry Seemann
It really hurts your feelings when you dent the door trying to set the socket. You can guess how I know. One of those mistakes you only make once.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 01-11-2011, 07:31 PM   #12
Charles Reese
i feel your pain! mine is on a quater panel .. ugh
