Old 05-29-2019, 11:49 AM   #1
old Tom
Default instrument panel lighjt
I have a instrumental panel with the oval speedometer. The light is in the center of the panel. I removed the panel to reverse the wires on the ammeter as it was reading backwards It reads normal now. I noticed the wire for the light was not connected to anything(I recently acquired the car) Could someone tell me how to wire it up. I tried to connect it to the key and it would only light when the key was off tried the other terminal and it would not work. I do not know how it was wired originally. Thank You.
old Tom is offline   Reply With Quote
Old 05-29-2019, 11:58 AM   #2
redmodelt
redmodelt's Avatar
Default Re: instrument panel lighjt
It mounts to the generator side terminal on the ampere meter.
Old 05-30-2019, 08:17 AM   #3
old Tom
how will I turn the light on and off? The ammeter terminal is hot all the time and there is no switch between them.
Old 05-30-2019, 08:23 AM   #4
midgetracer
midgetracer's Avatar
turning the knurled end of the light is the switch. It lifts the bulb off the hot wire.
midgetracer is offline   Reply With Quote
Old 05-30-2019, 10:32 AM   #5
1930 coupe
it connects to the ammeter. Twist the cover to the right to turn it on, twist to the left to turn off.
1930 coupe is offline   Reply With Quote
Old 05-30-2019, 12:56 PM   #6
California Travieso
Send a message via Yahoo to California Travieso
Since you only need it at night, could it be wired into the headlight circuit so it would only go on when you turn on the headlights?
David Serrano
California Travieso is offline   Reply With Quote
Old 05-30-2019, 05:39 PM   #7
Synchro909
Synchro909's Avatar
David Serrano
If that dash light is on for any prolonged time, it gets HOT! When mine ceased to work a while back, I considered wiring it on with the headlights and using an LED globe but it healed itself. It's now not broke so I won't fix it.
Old 05-30-2019, 05:52 PM   #8
CarlG
CarlG's Avatar
David Serrano
I have a '31 with the light buried up in the dash rail. But I wired it to come on whenever the tail lights are on. Don't have to worry about turning it on or off. I will replace the bulb with LED as soon as I determine which LED will work there.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-30-2019, 06:08 PM   #9
California Travieso
Thanks, Sychro and Carl. Yes, it gets hot with the regular bulb. I agree about replacing the bulb with an LED.
David Serrano
Old 05-30-2019, 09:34 PM   #10
SteveB31
SteveB31's Avatar
CarlG- our A-13465-L bulb is an LED that works in the stop light, tail light, dash light and dome light. Does not get hot. $7 each at modelastore.com
SteveB31 is offline   Reply With Quote
Old 05-30-2019, 10:13 PM   #11
30 Closed Cab PU
Thanks for posting your LED info. Have been searching, and have ordered and tried a couple of different LED lamps for the Dash Light - so far not happy. Will be ordering a couple from you next week.
Old 05-31-2019, 08:48 AM   #12
whirnot
whirnot's Avatar
My biggest complaint with the dash light, was it was too bright. Might be an issue with the LEDs as well. I put a 12 volt bulb in to cut the brightness.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-31-2019, 12:29 PM   #13
mngreen
mngreen's Avatar
CarlG--if you're running 12V this is the ticket ($6.95):
https://www.superbrightleds.com/more...fit/3698/8009/
I have one in my dash rail and is a PERFECT FIT and am very happy with it. I will also put one in the cowl lamps and tail light.
mngreen is offline   Reply With Quote
Old 05-31-2019, 02:52 PM   #14
5lugnuts
LED Light Bulbs and Lamps for 6 Volt Positive Ground Chassis
https://www.ledlight.com/6-volt-posi...ed-lights.aspx
https://www.ledlight.com/led-light-load-equalizer.aspx
https://www.superbrightleds.com/more...g-fix/190/831/
5lugnuts is offline   Reply With Quote
Old 07-03-2019, 08:41 PM   #15
jtt1957
can you send a pic of how it is mounted thanks
jtt1957 is offline   Reply With Quote
Old 07-03-2019, 09:23 PM   #16
Brian SATX
Brian SATX's Avatar
Steve B31- is that for 6V and 12 or are there different numbers?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 07-04-2019, 08:58 AM   #17
eagle
eagle's Avatar
One thing to remember. Most LED bulbs are polarity sensitive. I say most because there are some that run a circuit in them to automatically adapt to either polarity, however, they are not common. So, if you are running pos grd make sure the LED bulbs you buy are made for it.
Old 07-04-2019, 11:31 AM   #18
30 Closed Cab PU
Dash Light.I ordered some from these links, did not work, dug down into the specs and they were for 12V. I called them and asked for a 6V version, that exact design was not available in 6v. So I had them recommend a different 6 V, and when tried it was so dim it was useless. Currently, went back to the original incandescent.
Make sure you dig into the specs
Old 07-04-2019, 09:25 PM   #19
Brian SATX
Brian SATX's Avatar
Thanks for the info and research.
Brian SATX
