05-23-2013, 05:32 PM | #1 |
plastic fan size
I need to know the diameter of the plastic fans now being offered. Also, are there any clearance problems to the radiator? Thanks
05-23-2013, 05:41 PM | #2 |
Re: plastic fan size
I forgot the size, but NO clearance problems & they are very "SAFE"! Bumped mine with my elbow & it just goes-----BRRRP! Bill W.
05-23-2013, 05:49 PM | #3 |
Bert's sells a 6 blade black plastic fan 14 3/4 diameter.
NO Clearance problems on 29 Coupe |
05-23-2013, 09:56 PM | #4 |
No clearance problems with a '30 Coupe.
Dick |
05-23-2013, 10:14 PM | #5 |
If you get one from a model A vendor you will have no clearance issues, buy it from your local parts store and who knows.
05-24-2013, 10:23 AM | #6 |
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
05-24-2013, 10:29 AM | #7 |
Had plastic on my 30 PU replaced with 2 blade and runs much cooler now!
05-24-2013, 10:41 AM | #8 |
Put a plastic on my car. Runs much cooler at idle and low speeds. No difference at high speeds. Plus, it's safe.
Cowtown A's |
05-24-2013, 11:38 AM | #9 |
Rock: Somebody a while back posted figures ( I believe temps) comparing a 2 blade (orig), 4 blade and the plastic. The 2 blade ORIGINAL style provided the best cooling. Try a search. FWIW
Paul in CT |
05-24-2013, 12:28 PM | #10 |
Thanks Flamingo. I'm looking for something statisical, as most observances of cooling are mostly stated in generalities. I would like to be able to apply some thermodynamic formulas to determine the actual cooling characteristics of the different fans that are available. Some newer fans are listed by cfm at a certain rpm. I'll keep searching.
05-24-2013, 12:36 PM | #11 |
No cfm specs buit on my 30PU, after changing to 2 Blade and also Engine pans, In FL heat almost 25 degree drop! made me check to see if the plastic fan was on backwards but it was correct.
