Old 02-19-2019, 10:47 PM   #1
CT Jack
CT Jack's Avatar
Default Front Kick Panel Repair
The drivers side front kick panel in my 31 coupe has been unintentionally kicked a number of times while driving. The kick panel is cardboard stock covered with a fake leather grain material. The lower section which is near the clutch pedal is where the scuff damage is located. Does anyone have experience with making a repair like this besides buying a new one?
Thanks
CT Jack is offline   Reply With Quote
Old 02-20-2019, 02:00 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Front Kick Panel Repair
To my knowledge the original embossed cardboard is no longer available, so they make them as you described, with the vinyl cover. You might call Classtique upholstery and ask Mike for a piece of vinyl to glue on after removing the damaged one.
Old 02-20-2019, 07:49 AM   #3
Tinbasher
Tinbasher's Avatar
Another thought would be to put a small piece of rubber or adhesive backed felt, along the lower section where it getting bumped. To protect the panel for the future.
Tinbasher is offline   Reply With Quote
Old 02-20-2019, 08:16 AM   #4
30 Closed Cab PU
I've had grained leather and vinyl on furniture spot "reconditioned " due to scratches/scuffs at furniture re-upholstery shops. Hard to spot the repairs unless in bright light and really looking for it. Works best if damage to material is minor and not torn/gouged. Or perhaps an auto upholstery shop.
Old 02-20-2019, 02:14 PM   #5
1931 flamingo
1931 flamingo's Avatar
Deb's on the north bound side of Berlin Tpke coming from Meriden might be able to help??
Paul in CT
