Old 11-17-2019, 03:49 PM   #1
zoegrant
zoegrant's Avatar
Default T 86 oevrdrve issue
When I turn the key on the ignition and check current on the overdrive relay with a test light it shows that the current is live on both side of the fuse.
Shouldn't the relay only be live on one side as the car is not moving so the governor is not activated.
Does this sound like the solenoid points are stuck ?
zoegrant is offline   Reply With Quote
Old 11-17-2019, 05:00 PM   #2
Ole Don
Ole Don's Avatar
Default Re: T 86 oevrdrve issue
Hot on both sides of a fuse only means the fuse is good.
Ole Don is offline   Reply With Quote
Old 11-17-2019, 05:59 PM   #3
zoegrant
zoegrant's Avatar
with the key on the only relay connection that shows no current is the switch marked TWSH...should that be ?
I jacked up the car rear wheels and put the car on stands and with the car in high gear brought the car over 30 mph and the THSW still showed no power at that connection using my test light...should the governor have sent power to that connection ?
Old 11-17-2019, 06:24 PM   #4
40cpe
40cpe's Avatar
The governor sends a ground to the relay when the car reaches the preset speeds, so there would be no voltage present on that terminal. You would need to check for voltage on the "SOL" terminal when the car reaches about 30 to see if the relay system is operating.
40cpe is offline   Reply With Quote
Old 11-17-2019, 08:45 PM   #5
zoegrant
zoegrant's Avatar
Are you talking about power at the relay where the blue wire attaches on the drivers side of the relay under the hood ?
Or are you talking about the power wire on the solenoid under the car ?
If you are talking about getting power after 30 mph on the sol side of the relay under the hood, then I tried that and there is no power at that terminal even at the 30 mph speed.
Old 11-17-2019, 11:07 PM   #6
40cpe
40cpe's Avatar
I was talking about at the relay terminal. As a test of the relay, with the ignition on, put a jumper wire from the governor terminal to a good ground. It should click. If so, you should have power at the soleniod terminal.
If you Google "troubleshoot Borg-Warner overdrive" you will find lots of information and an understanding of how the overdrive works.
Old 11-17-2019, 11:31 PM   #7
dmsfrr
dmsfrr's Avatar
Originally Posted by 40cpe View Post
. . . . If you Google "troubleshoot Borg-Warner overdrive" you will find lots of information and an understanding of how the overdrive works.
Here's one relay troubleshooting link...
https://www.ctci.org/overdrive-and-p...s-bench-check/
dmsfrr is offline   Reply With Quote
Old 11-18-2019, 11:49 AM   #8
zoegrant
zoegrant's Avatar
OK...I appreciate all the help...I have traced the problem to the solenoid...the points were stuck together...I cleaned them up but need to know what " POINT SETTING" to use.
Also, the outside case is stamped with a numeral 6 on one and a number 4 on the other electrical terminal.
What does that mean ?
Old 11-18-2019, 01:15 PM   #9
rotorwrench
rotorwrench's Avatar
The THSW terminal on the power relay is the ground path to the governor switch connection where it actually grounds the circuit at ON speed. This is what activates the relay on the dash. When it activates, the relay energizes the coil and closes the power switch to the actuator soleniod on the transmission at terminal #4. Terminal #6 on the actuator solenoid is for kick down function.
I don't know why the actuator solenoid is marked the way it is but it has to have an ID marking of some kind to get it properly connected. It performs several functions inside in order to conserve electrical power in operation. It has an energizing coil and a holding coil so there are actually two sets of switch points in there. One to kick out the energizing coil and one to kick out the holding coil for kick down function. The engine ignition coil is momentarily cut off till that kick down set of points open and allow the ignition coil to resume function. That ignition cut off happens pretty fast so it's not so noticeable.
Old 11-18-2019, 01:39 PM   #10
40cpe
40cpe's Avatar
Before you start tampering with the points, you should determine if you hooked the power wire to the correct wire on the soleniod. As rotor said, one wire is to ground out the ignition, the other is to energize the solenoid. The heavier wire will power the solenoid, IIRC, it is the orange wire.
Old 11-18-2019, 04:18 PM   #11
zoegrant
zoegrant's Avatar
40cpe...I have adjusted the one set of points to .0005, 2mm.
It appears that the set of points that sit on top of the plunger is not adjustable.
On the wire harness that I purchased all the wires seem to be the same size, 16 gage.
The power wire has to be correct as my overdrive has been working for a while now. One day it just stopped working.
The first good day I will try it out and let you know how I make out...
Old 11-18-2019, 04:42 PM   #12
40cpe
40cpe's Avatar
Good, sounds like you have it figured out.
Old 11-19-2019, 11:45 AM   #13
Dobie Gillis
Dobie Gillis's Avatar
The set of points inside the solenoid on the side are the heavy amperage pull-in points; the points on top are the lower amperage hold-in points and are normally closed until the kick down feature is activated. The pull-in points should open as soon as the plunger extends leaving only the hold-in points live. When driving torque is released by lifting your foot the plunger completes its travel due to spring pressure pushing the pawl into engagement with the drive plate, stopping its rotation and directing the driving torque through the OD. If the pull-in points don't disconnect the heavy amp draw will eventually burn the windings in the bottom of the solenoid, destroying it.
Diapers and politicians should be changed often and for the same reason.
Mark Twain
Dobie Gillis is offline   Reply With Quote
Thread Tools
Display Modes
