Old 10-15-2019, 09:19 PM   #1
Don T
Default 50 shoebox diff
Can someone confirm that the pinion setting is set by crush washer or is it set by shims in this diff. Thanks for the help.
Don T is offline   Reply With Quote
Old 10-16-2019, 07:50 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: 50 shoebox diff
I believe it is a crush washer or spacer.
if you're replacing a seal just mark the nut to the shaft for reference, If you did not do that then just tighten it and check bearing preload, which I usually do bt feel. Not loose but just some drag.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
