Old 11-12-2019, 07:49 PM   #1
cfordman
Default 1962-63 f 100 ft whl cylinders
Cant find the original one piston wheel cylinders for a 1963 f100 front drum. Is there a solution by using 64 or later wheel cylinders? The brake shoes have slots for both piston arms.
cfordman is offline   Reply With Quote
Old 11-15-2019, 01:15 AM   #2
KULTULZ
KULTULZ's Avatar
Default Re: 1962-63 f 100 ft whl cylinders
Again, I hate to do it but the best source for this info will be here -
https://www.ford-trucks.com/forums/index.php
If you are still here, please share the answer with this board.
As we got into bed, I asked the wife if there was a chance of having sex tonight ...
As usual, the reply was, "Not likely".
"Well then, can I call a friend"?
And that's when the fight started ...
UPDATE - The doctor said I will walk again but most likely with a limp ...
KULTULZ is offline   Reply With Quote
