Old 11-10-2019, 04:07 PM   #1
DannL
DannL's Avatar
Default What spark plugs are you currently using?
Yeah, consider this a poll. Give the brand and part number of your plugs. Are you happy with them?
DannL is offline   Reply With Quote
Old 11-10-2019, 04:14 PM   #2
160B
160B's Avatar
Default Re: What spark plugs are you currently using?
Champion 429 Spark Plug AKA Champion 3X
Very happy with the 3X
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 11-10-2019, 04:24 PM   #3
F.M.
Ditto, Originals and Reproductions
F.M. is offline   Reply With Quote
Old 11-10-2019, 05:00 PM   #4
AL in NY
AL in NY's Avatar
Running original 1930's vintage Champion 3X plugs. They run great. Wouldn't consider anything else!!!
AL in NY
AL in NY is offline   Reply With Quote
Old 11-10-2019, 05:33 PM   #5
30 Closed Cab PU
W18s, happy with them, 3076 were too cold.
Old 11-10-2019, 05:57 PM   #6
DannL
DannL's Avatar
Champion W16Y. The car runs good, but do have some fouling. We're working on it.
Old 11-10-2019, 06:01 PM   #7
rfitzpatrick
What does it mean when you said they're to hot/cold plz. I really don't understand.
Thanks
rfitzpatrick is offline   Reply With Quote
Old 11-10-2019, 06:37 PM   #8
Conaway2
Conaway2's Avatar
Just installed Champion 3X’s last week - very happy so far with them.
Conaway2 is offline   Reply With Quote
Old 11-10-2019, 06:52 PM   #9
160B
160B's Avatar
Thanks
Spark plug heat range is the measure of how fast the spark plug tip dissipates combustion heat. It must do this in a precise and controlled manner so the spark plug will:
Stay cool enough to avoid pre-ignition and/or electrode destruction due to detonation.
Run hot enough to burn off combustion deposits that would otherwise collect on the sparkplug insulator tip and cause fouling, that leads to misfire.
Adapt to specific engine characteristics and widely varying driving/load conditions.
"Hot" spark plugs remove heat from the combustion area relatively slowly. They have a longer insulator tip and they achieve a temperature higher than the deposition zone relatively fast.
"Cold" spark plugs feature a relatively short insulator tip and they remove heat from the combustion area quite fast, in order to avoid advanced ignitions.
The choice of a proper heat range is very important. But even a spark plug featuring a properly selected heat range, is influenced by the processes of fouling and self-cleaning of the insulator tip. The setting of combustion deposits on the insulator tip is caused by an imperfect combustion due to a "rich" air/fuel mixture. On the other hand, the combustion deposits previously set will burn if the insulator tip temperature rises above 475 C.
Zones of spark plug fouling and self-cleaning zone depending on the air/fuel ratio and on the spark plug insulator tip temperature.
https://www.briskusa.com/spark_plug_...at_range_chart
Old 11-10-2019, 07:02 PM   #10
Werner
Werner's Avatar
Thanks
Internal combustion engines run at different temperatures. If more specific power, the combustion chamber gets hoter temperature. (Very simplified explanation.)
Simply explained: The hotter engine burns needs the colder the ignition plugs must be. (This interpretation is unfortunately not uniform; in Japan, the standard designation, for example, vice versa. I do not know USA.
Rule of thumb: Hot engine need 'cold' plug. Cold engine 'hot' plug.
For me, the global standardization of of the interpretatin "a plug is hot or cold" is difficult to explain.
If the spark plug does not get hot enough, it will become sooty. If it overheats, there is dangerous high speed knocking!
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 11-10-2019, 08:06 PM   #11
Bob-A
Bob-A's Avatar
Smile Re: What spark plugs are you currently using?
Champion W18's with a Pertronix FlameThrower coil!
Bob-A
Bob-A is offline   Reply With Quote
Old 11-10-2019, 08:23 PM   #12
Patrick L.
Patrick L.'s Avatar
3077 Autolite. Been using them for probably 30 years, wish I could still find them.
There was a recent similar thread.
Old 11-10-2019, 08:35 PM   #13
The Master Cylinder
The Master Cylinder's Avatar
https://www.fordbarn.com/forum/showt...ght=spark+plug
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-10-2019, 09:45 PM   #14
supergnat
supergnat's Avatar
The current 3X’s I’ve seen have dual grounds (I think that is what they are called). Is that an improvement/. Are they good for our Model A’s?
supergnat is offline   Reply With Quote
Old 11-10-2019, 10:03 PM   #15
F.M.
Originally Posted by supergnat View Post
The current 3Xs Ive seen have dual grounds (I think that is what they are called). Is that an improvement/. Are they good for our Model As?
Pictures of them, both styles can be seen in the Restoration Guidelines..
Old 11-10-2019, 10:20 PM   #16
The Master Cylinder
Interesting, I have not seen a dual ground 3X.
The Master Cylinder
Old 11-10-2019, 10:24 PM   #17
F.M.
That is because their is none....
Old 11-10-2019, 10:25 PM   #18
jw hash
jw hash's Avatar
I have been running original champion 3X`s in my Victoria for over 25 years. and I also run repro, 3X`s in the 160A. with unleaded fuel the plugs last a lot longer, the 16Y`s are to cold for me.
jw hash is offline   Reply With Quote
Old 11-10-2019, 11:05 PM   #19
Boston Bruce
Boston Bruce's Avatar
Champion 3X
Boston Bruce is offline   Reply With Quote
Old 11-10-2019, 11:08 PM   #20
supergnat
supergnat's Avatar
Boy, Am I red faced. 😱. I was mistaken. The online photos have a shadow which makes it appear as though there is a second ground. I apologize for the oversight.
