Old 02-20-2017, 06:42 PM   #1
duke36
Default Motor Mount rubber
Would like to know the correct thickness of the flat rubber between the original mounts and frame; the vendors pads appear to be too thick.
duke36 is offline   Reply With Quote
Old 02-20-2017, 06:46 PM   #2
Art Newland
Art Newland's Avatar
Default Re: Motor Mount rubber
FWIW, I just installed a new set, and it went together fine. Pretty sure I got them from Brattons.
Art Newland is offline   Reply With Quote
Old 02-20-2017, 06:48 PM   #3
Dollar Bill
Dollar Bill's Avatar
I don't have the dimensions but the ones I got from Brattons about 2 years ago were too thick. Ordered from Snyder's and they fit perfectly.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 02-20-2017, 06:50 PM   #4
SeaSlugs
SeaSlugs's Avatar
mine from snyder a year ago were fine.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-20-2017, 07:00 PM   #5
Keith True
Keith True's Avatar
Remember,they're not just flat pads.They have little sleeves molded onto the three holes that fit through the frame.
Keith True is online now   Reply With Quote
Old 02-20-2017, 07:30 PM   #6
CarlG
CarlG's Avatar
I bought a set from Berts and another set from Snyder's. If I remember correctly, I used the rubber from Snyder's and the hardware from Bert's. That combination finally worked.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-20-2017, 09:06 PM   #7
Steve Plucker
Steve Plucker's Avatar
The ones I got from Brattons were to thick and to hard...The ones I got from Snyders were perfect.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Old 02-20-2017, 09:09 PM   #8
BudP
BudP's Avatar
My experience also: Bratton's were too thick, Snyders were a good fit.
BudP is offline   Reply With Quote
Old 02-20-2017, 10:43 PM   #9
califfarmer
califfarmer's Avatar
I installed the Snyder's rubber last week and slide the engine in place with only a little help from my teenaged son. They fit great
Eat more large Lima beans!!
califfarmer is offline   Reply With Quote
Old 02-20-2017, 11:54 PM   #10
Larry Jenkins
Not quite right. The one's from Snyders has the molded in sections where the supplied steel tubes slip in to prior to assembly.
The engine dropped right in without a frame jack or any adjustments to the engine mount assemblies
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 02-21-2017, 12:09 AM   #11
Mike V. Florida
Mike V. Florida's Avatar
Too thick or too thick for your car?
"The rubber pads between the rear motor mount to frame and frame to support mounting plates. 4 pieces. Unlike others on the market ours are made to the original blue prints."
motor-mount-pads
Old 02-21-2017, 12:25 AM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Isn't that what Keith said?
The last 3 sets I bought from Snyder's over 5 years have been a perfect fit.
Old 02-21-2017, 07:07 AM   #13
Keith True
Keith True's Avatar
That is what I said,or,at least,it's what I was trying to say.
Old 02-21-2017, 11:17 AM   #14
duke36
Have a set that came in an extra parts box and seem to be very thick and not sure where they came from. Just would like a thickness dimension of some inner pads that work. I guess we'll try the vendors. BTW, we are so fortunate that there are excellent vendors with parts for our cars. Try to find spider gears for mid to late '20's De Sotos !!
Old 02-21-2017, 04:34 PM   #15
Larry Jenkins
For the Snyders parts, the sleeves are not "molded in" the rubber. They are loose and must be installed before final assembly.
Sam Ting..
Maybe my old eyes are getting worse..
Old 02-21-2017, 05:29 PM   #16
Keith True
Keith True's Avatar
I guess I've never seen them like that.All the ones I've used have half the rubber sleeve molded on one part,and the other half on the other.Then they meet somewhere in the middle of the frame and the little steel bushing pushes through the two halves.
Old 02-21-2017, 05:46 PM   #17
2manycars
2manycars's Avatar
Here are two photos of rubber pads that I photographed several years ago. The thin ones were very old, and the thick ones were what was being offered at the time.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 02-22-2017, 01:53 PM   #18
duke36
thank you 2many; that 's kind of what I remember from originals tossed. It's the inside frame rubber that is too thick.
Old 02-22-2017, 06:11 PM   #19
Step-down
Step-down's Avatar
Spread the frame slightly , port-a- power of make one with threaded rod and a pipe. Don't need much , thick or thin .......
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Thread Tools
Display Modes
