12-14-2012, 07:44 PM | #1 |
New CAM
I was just reading the threads on installing a new cam with the engine in the car.
Why do you have to remove the oil pan? I was able to get mine in without removing the oil pan did I mss something? Ed |
12-14-2012, 07:56 PM | #2 |
Re: New CAM
You have to remove the pan to change the lifters. You must have adjustables already in place. I hope
12-14-2012, 08:05 PM | #3 |
Re: New CAM
Yes I had adjustable lifters and just wired them up to hold them up.
Thanks |
12-14-2012, 08:16 PM | #4 |
Re: New CAM
I changed a cam several years ago and used clothes pins to hold up the lifters.
12-14-2012, 09:30 PM | #5 |
Re: New CAM
The lifters would have to be perfect, or they should be changed along with the new cam. If a cam lobe is worn I'd think at least that one lifter would be also.
12-15-2012, 09:54 AM | #6 |
Re: New CAM
Gar Williams |
