10-23-2017, 10:15 AM | #1 |
Anyone have a close up picture of a '28 crank hole cover assembly?
Would really appreciate seeing a close up picture of how the rivet holds the crank hole cover on a '28 grille shell. I'm assuming there is some type of spring that provides tension to keep the cover from swinging back and forth.
10-23-2017, 11:17 AM | #2 |
Re: Anyone have a close up picture of a '28 crank hole cover assembly?
Hi Tim,
No, I believe no spring.. The cover does swing around on mine. I pulled a piece of fishing line around the rivet to stop it. Can't post a photo as I am visiting in the UK for another week.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
10-23-2017, 11:18 AM | #3 |
OK, thank you. Hhhmmm, I may rig up a spring set-up to keep it from tic-toc around.
10-23-2017, 11:22 AM | #4 |
Tim,
So many other noises, you will not hear it tick-tocking around
10-23-2017, 11:27 AM | #5 |
10-23-2017, 11:59 AM | #6 |
Rusty Nelson |
10-23-2017, 12:31 PM | #7 |
In the 80's I had an A coupe and I was also bothered by the loose cover. Instead of a plain rivet, I used a threaded rivet with a spring. If I remember right, it took a fairly stiff spring to make it feel right. If I were to do it again, I may try a couple of belleville washers instead.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
10-23-2017, 01:19 PM | #8 | |
Rusty: Thank you. For sure I have the wrong rivet. Mine is the one you describe. OK, now I'm determined to make this work. |
10-23-2017, 04:53 PM | #9 |
Our 28
10-23-2017, 06:01 PM | #10 |
Nice pic iverson.
So refreshing to see what they were really like, after the cheap repo crap we have to fit. |
10-23-2017, 08:33 PM | #11 |
Fellas
Are the correct rivets still available? I know someone mentioned a supplier in an above post. The repop one is a joke. |
