09-03-2012, 01:37 PM | #1 |
grinds in all gears
Hi,
I am working on a 30 coupe and my question is when trying to shift into first the trans grinds a lot before it will go into gear. The engine r.p.m. is very low and the clutch is adjusted properly, I removed the inspection plate in the bell housing and the throu out bearing is not spinning with the clutch out. I suspect something is dragging but I dont know, the engine was just installed 2 months ago by the owner. Any help would be great before I have to pull the rear and trans. Mike1931
Mike 1931 |
09-03-2012, 01:40 PM | #2 |
Re: grinds in all gears
With the clutch pedal depressed is the trans input shaft turning?? What do you have for lube in the tranny??
Paul in CT |
09-03-2012, 01:58 PM | #3 | |
1927 Model T 1930 Standard Roadster 1930 5 window coupe 1931 Tudor Sedan "If it was easy, everyone would do it" |
09-03-2012, 02:42 PM | #4 |
I have found that with the heavy weight transmission oil, when it is cold it does grind a little when engaging first gear, once warmed up, it is less of an issue, you still need to be gentle. Also in my opinion, the heavier oils will slow the transmission gears more so than a 90 weight oil, which should assist in engaging first gear less grinding. As Paul in CT asked, what oil do you have in the tranmission?
Paul in NZ |
09-03-2012, 02:44 PM | #5 |
As 1931 flamingo asked, make sure you have the proper 600 wt (as the venders sell it) in the tranny. It needs to be thick enough to slow the gears down enough for a proper mesh. Remember it's non synchronized.
09-03-2012, 02:55 PM | #6 |
09-03-2012, 03:29 PM | #7 |
Thanks for all the input, I drained & serviced the trans with 600 w gear oil from Brattons, it seems like something is lagging. If you were to run at a higher r.p.m. like 3 clicks down on the quadrant that is what I am experiencing, no problems shifting, just acts like the idle is set way to high which it is not. I will look later this week and see if the input shaft is moving
Mike 1931
Mike 1931 |
09-03-2012, 03:42 PM | #8 |
There are two adjustment for the clutch. One is where you adjust the linkage to the clutch pedal. This adjustment positions the throw-out bearing back away from the fingers on the pressure plate. The other adjustment is supposed to be done by whoever assembled the pressure plate. However, many times this is not done correctly. This may be your problem in that the clutch is not fully engaging. You can check it through the inspection port in the bell housing. each finger should be positioned between 5\8" and 3\4" (11\16" being nominal) from the back surface of the pressure plate housing, and they should all be equal.
It is possible to re-adjust them using a screwdriver and a box wrench. You may first have to cut the area on each stud that is peened over. Tom Endy |
09-03-2012, 06:53 PM | #9 |
Thanks for the info I will let you k ow how I make out later this week
Mike 1931
Mike 1931 |
09-03-2012, 08:01 PM | #10 |
Are you trying to shift into first while moving or sitting still?
Being its a non-syncronized trans shifting into first while moving requires double clutching. |
09-04-2012, 12:02 PM | #11 |
No the car is stopped idle low and it grinds bad going into first gear every time.
I think his pressure ate is weak Mike
Mike 1931 |
09-04-2012, 01:35 PM | #12 |
look for a crack in the clutch lever that is mounted on the shaft on the outside of the bellhousing. I had a very small one and even thought I had adjusted everything correctly, it still would grind going into gear, as the lever would flex rather than properly rotate the shaft to engage the throwout. Often you need to have someone else depress the pedal while you look at the lever to see if there is any flex. mine looked great, but under pressure, you could definitely see the crack.
09-04-2012, 03:50 PM | #13 |
If the vehicle has sat for a length of time,, there may be enough rust build-up to not allow the clutch to completely disengage.. Driving it for awhile should/may help scrape it away,, its kinda normal..
09-04-2012, 05:28 PM | #14 |
Maybe an issue with the pilot bearing.
Bob |
09-04-2012, 05:47 PM | #15 | |
Adjust the freeplay at the top of the pedal travel. (need less) |
09-05-2012, 06:52 AM | #16 |
The clutch adjustment is set properly, I adjusted the free play from zero clearance to 3 inches makes no difference. Now it is set to 1 inch free play and the throu out bearing is not spinning.
Mike 1931 |
09-05-2012, 08:03 AM | #17 | |
Don't you love it when people respond by just reading the first post rather than following the entire thread? |
09-05-2012, 09:19 AM | #18 |
If either of the two levers on the clutch shaft is cracked you can feel the 1 inch freeplay, but still not disengage the clutch disc even though you feel some resistence. The crack will spread and cause lost motion. Best to have someone push the clutch while you look for a crack, or you can remove the inspection cover for the clutch and view the T/O bearing movement while stepping down on the clutch. If this checks out fine, then maybe some clutch lining is stuck to the disc or flywheel, or a disc spring may have come out of place. Or, you may have a bent clutch disc. This can happen when someone lets the tranny weight hang on the clutch disc splines.
Even if you happen to have thin oil in the tranny, you should be able to double clutch and not grind, or wait a longer time when at a stop sign and the clutch disc should eventually stop spinning with the clutch pedal depressed. |
09-05-2012, 10:20 PM | #19 |
I had a similar issue with one of my model a's and found that the nuts on the pressure plate fingers had not been locked in properly and some had come loose quite a distance. This made it impossible to get freeplay and the clutch disengaged with the pedal stroke. After properly adjusting these nuts and locking them in place, everything worked fantastic. maybe worth looking through the inspection plate and looking to see that the nuts are all about the same adjustment.
10-06-2012, 08:07 PM | #20 |
Hi all. Have just come across this post....just a thought. Is it possible for the clutch disc to have been installed wrong way about and not allowing sufficient movement for clutch fingers to fully disengage clutch?
