Old 05-19-2018, 01:54 PM   #1
F-word541
F-word541's Avatar
Default 56 292 spark plugs
I am looking to get new plugs for my 56 wagon. It's got the original 292 that I put an autolite 4100 carb on. I was running pertronix ignition until it failed. I went back to the points and condenser. Pretty sure I want to go with a copper core plug, but I see that some say resistor or non-resistor. Not sure what the difference is or which one to go with. Any thoughts?
Proud driver of the F-word. 56 Country Sedan wagon, 84 250 diesel, 04 Expedition.
F-word541 is offline   Reply With Quote
Old 05-19-2018, 02:59 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 56 292 spark plugs
Part of the reason for 'resistor' plugs or wires is to cut down on static in the AM radio.
They also reduce stray magnetic fields around the plug wires that can... interfere with some electronic ignition systems.
I'll let someone who knows about specific spark plugs answer your original question.
Old 05-19-2018, 03:24 PM   #3
Ole Don
Ole Don's Avatar
I really liked the NGK plugs that I bought at O'Riellys. They outlasted Champions by four to one. I gapped them at .030 to .032
Ole Don is offline   Reply With Quote
Old 05-19-2018, 04:03 PM   #4
mikhett
I also prefer NGK PLUGS in my Ford Fe 390
mikhett is offline   Reply With Quote
Old 05-19-2018, 04:38 PM   #5
KULTULZ
KULTULZ's Avatar
Post Re: 56 292 spark plugs
Here is an excellent tutorial on RESISTOR/SUPPRESSION spark plugs. Scroll down to RESISTOR-
https://www.ngk.com/glossary/8/spark-plug/R
At the moment the spark jumps the Gap it causes a high frequency burst of energy, known as RFI (radio frequency interference). RFI, as its name suggests, creates static on your radio and interference with other electronic equipment, including the vehicle’s on-board electronic control units (ECUs).
Resistor plugs were developed in the 1960s to suppress some of the spark energy, thus lowering RFI to an acceptable level. Most Resistor spark plugs use a monolithic Resistor, generally made of graphite and
glass materials, to filter the electrical voltage as it passes through the Center Electrode.
Since Resistor type plugs actually “resist” some of the spark energy, non-Resistor type plugs actually deliver a more powerful spark. It is for this reason that most racing plugs are non-Resistor types. However, in most automotive applications, a Resistor plug is required for proper vehicle operation. Use of non-Resistor plugs in
vehicles that call for a Resistor type can result in rough idling, high-rpm misfire, and abnormal combustion.
In fact, the entire site will prove very educational IMO.
Concerning your period engine, a quality set of IGN WIRES (also discussed within the site) will give you adequate suppression allowing the plugs (non-resistor) to deliver a hotter spark (again IMO).
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 05-27-2018, 06:43 AM   #6
KULTULZ
KULTULZ's Avatar
Thumbs up Tech article
- WHY IS IT ... -
Old 05-27-2018, 08:41 PM   #7
paul2748
paul2748's Avatar
I use Autolite 46's for years and never had a bad one.
48 Ford Conv
56 Tbird
54 Ford Victoria
