Old 07-04-2018, 02:40 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Bosch (blue can coil) for 6v
Read where I can substitute blue Bosch (?) can coil for my stock 42 crab distributor coil. Sounds like an easy swap (and cheaper but not stock) after making a bracket to hold it. Any weird stuff to look out for? Is the blue coil 6V ? Thanks
Old 07-04-2018, 02:48 PM   #2
flathead 53
Default Re: Bosch (blue can coil) for 6v
Im pretty sure the bosch coil has an internal resistor ,so you would by pass the one under the dash . I did the same thing on my 40 coupe.
flathead 53 is offline   Reply With Quote
Old 07-04-2018, 03:32 PM   #3
meric42
meric42's Avatar
I believe that these are a true 6V coil with no ballast resistor, but you do still need to bypass the ignition resistor.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 07-04-2018, 03:37 PM   #4
51504bat
51504bat's Avatar
The Bosch 012 blue coil I'm running on the 8ba in my '39 is 12 volt with an internal resistor. Bosch makes a "blue coil" in 6 volts but its now silver, part number 0 221 124 001.
Old 07-04-2018, 04:11 PM   #5
JSeery
JSeery's Avatar
No resistor is required with a 6v coil assuming it is around 1.5 ohms.
Old 07-05-2018, 08:47 AM   #6
38bill
38bill's Avatar
http://www2.cip1.com/ProductDetails....-0-221-124-001
Here are the specs.
38bill is offline   Reply With Quote
Thread Tools
Display Modes
