06-10-2012, 08:33 PM | #21 |
Re: My new project 1928 Ford!!!!!
And a few more pictures now showing making the rear quarter panels out of the two rear doors and were shortened down to 12 inches in width and the pillar post cut to be use on both sides.
Frenchy |
06-10-2012, 10:11 PM | #22 |
very nice project was the windshield frame custom made or bought that way? thanks gump
06-10-2012, 11:26 PM | #23 |
I bought this project with this windshield I have always like the look of them.
Frenchy |
06-10-2012, 11:35 PM | #24 |
07-05-2012, 03:32 PM | #25 |
Here are a few pictures of the progress on my project.
Thanks Frenchy |
07-05-2012, 03:37 PM | #26 |
Thanks Frenchy |
07-06-2012, 01:12 PM | #27 |
A few more pictures of the passenger door. I will have some type of bead roll done.
Frenchy |
07-06-2012, 01:49 PM | #28 |
Two things to add here one: it's quite simple to adapt a Toyota 5 speed to a Ford steel bell housing, I just finished one. Second I just heard of a fellow thats putting two V8 60's to gether to form a V16. nOT SURE WHAT IT'S GOING IN.
07-06-2012, 03:51 PM | #29 |
Ron thanks for the heads up. Do you know which Toyota model had the 5 speed you mentioned. Do you have pictures of the modification you made you could post.
Thanks Frenchy |
07-06-2012, 06:08 PM | #30 |
Frenchy - Your body work skills are pretty impressive! Neat project.
07-06-2012, 07:35 PM | #31 | |
Frenchy |
07-06-2012, 07:52 PM | #32 |
I think it's a W-55 or W-56, I'm doing the machine work for someone else so I'm not firmiliar with Toyota transmissions. Yes I have some pics of the mods and will post them. Waiting for the bell housing to come back from the sand blasters.
07-06-2012, 09:01 PM | #33 | |
I appreciate you helping me with this just curious to see how it is set up. Frenchy |
07-06-2012, 09:32 PM | #34 | |
07-06-2012, 10:08 PM | #35 |
This happened to my friend George back a few years ago.
07-07-2012, 03:05 AM | #36 | |
Walt Thanks I found a pair of Mercury heads and I am having them magnuflux to make sure they are OK to use the ones in the pictures are Ford I am not going to use them unless the other heads have an issue. Frenchy |
07-07-2012, 07:14 AM | #37 |
I would use the EAB heads, they are smaller and give more compression. If that is accually a merc engine with the 4in. crank, the EAB heads will bring it right to the front. Walt
07-07-2012, 11:30 AM | #38 | |
It is a 1953 Mercury motor after I did some research on it. Thanks Last edited by frenchy dehoux; 09-04-2012 at 08:11 PM. |
07-07-2012, 06:47 PM | #39 |
The Merc heads are low compression similar to the 8RT. Not a good choice for a street engine
07-07-2012, 08:42 PM | #40 |
Ron
How about if I machine the heads to give it the same compression the EAB heads have what do you think. Thanks Frenchy |
