Old 01-01-2020, 01:00 PM   #1
CA Victoria
CA Victoria's Avatar
Default 1937-39 Steering Box
I will be looking for a 37-9 Ford Steering box.
When looking thru the piles at our swap meets how do i tell them apart from other years?
Thanks!
Tim
Downtown, Ca
CA Victoria is online now   Reply With Quote
Old 01-01-2020, 01:13 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1937-39 Steering Box
here is a housing on EBAY.
https://www.ebay.com/itm/Original-19...UAAOSw-IheB6x2
Old 01-01-2020, 01:29 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Hey Tim...Here's a good comparison pic. The larger box on the left is a 1939 ('37 & '38 also). The same basic box is used all the way thru '48, except that the lower cap where the light switch is located becomes merely a flat plate in 1940 because '40 went to a modern headlight switch. The smaller box on the right is a '36. DD
T5 W/TORQUE TUBE
It's one thing to be ignorant! It's a whole 'nother story when you're proud of it!
V8COOPMAN is online now   Reply With Quote
Old 01-01-2020, 01:38 PM   #4
deuce_roadster
deuce_roadster's Avatar
If the mast jacket is still on it there should be no place for column shift (40 and later) and should have headlight switch type bottom plate. The lock collar might be in a different place on some years but not sure on where it is on a 37-9 shaft if mast jacket is off.
Old 01-01-2020, 01:52 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Deuce....You need one more cup of coffee. With respect, I believe you meant to say that there SHOULD BE a place for column shifter ('40 and later).
T5 W/TORQUE TUBE
Old 01-01-2020, 02:12 PM   #6
Andy
One clue to tell a 37-39 from a 40-48 is the bottom plate. The 37-39 should have the adapter to mount the light switch. If no adapter, look to see if the tube going up inside the steering shaft is brass or steel. Brass is 37-39.
The bottom plates with the brass tubes can be found. You can also change them out with 13/32" brass tubing found at hobby shops.
Andy is offline   Reply With Quote
Old 01-01-2020, 02:50 PM   #7
CA Victoria
Good info, seeing the pictures of the two side by side helps.
On to Turlock.
Tim
Downtown, Ca
Old 01-01-2020, 03:00 PM   #8
Kube
Kube's Avatar
All the tubes I've encountered through '48 were brass.
Kube is online now   Reply With Quote
Old 01-01-2020, 03:10 PM   #9
deuce_roadster
V8coopman, wasn't the question how to identify a 37-39 column? My understanding is that a 37 to 39 mast jacket would not have a place for column shift which the 40-48s would have. ( I did only have 1 cup of coffee!) Happy New Year!
Old 01-01-2020, 03:39 PM   #10
Kube
Kube's Avatar
One CUP? Poop! I just finished my second POT. Baby...
Old 01-01-2020, 03:55 PM   #11
Andy
I have many of both kinds of bottom plates. The brass tube ones have thinner wall tubes so the horn rod will go thru. The steel ones used 40–48 will not let the horn rod go thru.
Old 01-01-2020, 04:24 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Deuce....You are absolutely correct with THIS entire statement, and I know that YOU (of all people) understand how all this stuff works, but in your original comment you said......"there should be no place for column shift (40 and later)". DD
T5 W/TORQUE TUBE
Old 01-02-2020, 12:41 AM   #13
deuce_roadster
DD I was trying to describe what the poster would see on a 39 mast jacket and I see I omitted the word "like" when I typed (40 and later). I hope I didn't confuse the poster. Sometimes when I am typing the whole thought doesn't make it from my brain to my fingers!
Next time I will try to wait until after the second cup! Thanks!
Old 01-02-2020, 09:41 AM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
I knew exactly what you meant in your first post, but then a newbie reading that might have gotten a bit confused, so it was well worth clarification, especially for someone reading this post a few years from now
John
Old 01-02-2020, 11:45 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
I knew that YOU have it all straight in your head, but like John (JM35) said below, I just wanted to avoid any possible confusion amongst the newbies and others needing the true scoop. Respectfully....DD
T5 W/TORQUE TUBE
