Old 05-15-2019, 09:42 PM   #1
Ruth
Default Harmonic Balancer
Model A Harmonic Balancer discussion continued from earlier Thread. https://www.fordbarn.com/forum/showt...bration+damper
I felt I was high jacking this thread on Gear Backlash by continuing to ask questions on Engine Restorations LTD Harmonic Balancer so I started this new thread.
From previous thread;
Originally Posted by Ruth View Post
I have never seen a Harmonic balancer pulley for a Model A. It sounds like an excellent idea. Are they only available in New Zealand?
Originally Posted by wensum View Post
The new Zealand made Damper is the same size as the original pulley but only a little bit deeper. The cost including shipping is very reasonable. "These dampers are made by Murray Horn in Levin N.Z. His Company is Engine Restorations Ltd. His email is [email protected]
Murray says this is the best way to contact him.
The dampers are a straight fit to replace the standard Model A pulley. An added benefit is a shallow reverse scroll in the rope seal area to help contain oil.
Yes the replacement harmonic balancer pulley simply replaces the original pulley. However, due to its extra depth it sits quite close to the front spring U bolts, and it is necessary to install the fan belt before fitting the pulley as one can't feed a fan belt in once the pulley is installed
Originally Posted by SAJ View Post
I carry a linked belt in both cars with the harmonic balancers. This makes it easy to replace a broken belt. These linked belts are good for tens of thousands of miles.
SAJ in NZ
After some thought and talking to Murray I decides to try one of his harmonic Balancers.
I received my harmonic balancer today. Nice piece. Weighs 5 - 5 1/2 lbs. Can I assume with the “reverse scroll” that a modern lip seal can not be used? I’m running a modern seal now.
I did pose this question to Murray but have not heard back yet. I was just wondering if anyone on the Barn had experience with this.
Thanks, Ruth
Old 05-15-2019, 10:09 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Harmonic Balancer
From New Zealand. I've heard good reports but haven't had a chance to try mine yet. SOON though.
Old 05-15-2019, 11:14 PM   #3
Ruth
Yes from New Zealand. I just heard back from Murray. He confirmed to use the rope seals. It will be a bit before I can install mine also.
Old 05-15-2019, 11:15 PM   #4
Dan McEachern
I contacted him also and had the same question regarding the spiral on the seal surface, but I have not asked if they are available without the spiral, as I want to run a modern seal in the front and a lip seal won't last long with the spiral.
Dan McEachern is offline   Reply With Quote
Old 05-16-2019, 12:50 AM   #5
Pete
Pete's Avatar
You could put a Speedisleeve on it.
Old 05-16-2019, 09:20 AM   #6
Ruth
I had not thought about the spiral on the seal surface either. I had wanted to run my Bill Stipes front seal that is on the car now.
That may be something to look into.
Old 05-16-2019, 09:29 AM   #7
whirnot
whirnot's Avatar
So, it appears that were you to break a fan belt, you would have to remove the front pulley in order to replace it?
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-16-2019, 09:51 AM   #8
Ruth
I think you would have to jack the engine up. It sounds like a hassle I know. But how often do you break a fan belt?
I am going to carry one of these belts with me 'just in case'.
Old 05-16-2019, 11:34 AM   #9
JOHN CT
JOHN CT's Avatar
I have a 31 tutor. I’ve changed a few fan belts in the past 20 years and I have enough clearance to change the belt without removing the pulley. Isn’t that the way it should be?
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-16-2019, 01:23 PM   #10
CarlG
CarlG's Avatar
Where do you get this type of belt?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-16-2019, 01:33 PM   #11
Pete
Pete's Avatar
Grainger. Harbor Freight. Ebay. Most any industrial V belt supplier.
These have a big advantage in that they do not flutter at high speed and cause vibration like a standard V belt.
Old 05-16-2019, 04:47 PM   #12
wensum
wensum's Avatar
I'm running a modern seal with my harmonic balancer without problems or leaks.
wensum is offline   Reply With Quote
Old 05-16-2019, 04:51 PM   #13
Synchro909
Synchro909's Avatar
They are available with or without the spiral so rope or modern seal compatible.
Old 05-16-2019, 05:25 PM   #14
john in illinois
john in illinois's Avatar
What are the benefits of this balancer. I probably missed it because I did not see earlier threads.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 05-16-2019, 05:44 PM   #15
Pete
Pete's Avatar
John
Longer crankshaft life.
The heavier the damper/balancer or the lighter the flywheel/clutch assembly, the better. It has to do with reducing torsional vibration in the crank. You can't normally feel this vibration in the seat of the pants.
Old 05-16-2019, 06:00 PM   #16
Ruth
I got it at Rubber Belts Online. They sell it by the foot. it is called PowerTwist Plus. The ⅝" size fits Model A pulleys.https://www.rubberbeltsonline.com/category-s/334.htm
I wish I had known that when I ordered it. Murray never mentioned it when I asked him about using a modern seal.
Does your harmonic balancer have the spiral?
Old 05-17-2019, 06:27 AM   #17
tinkirk
tinkirk's Avatar
Thumbs up Re: Harmonic Balancer
I'm running a modern seal with mine, I've got about 400 miles on it sense installed and no issue's as of yet, and yes i do believe it makes a difference!
Terry
tinkirk is offline   Reply With Quote
Old 05-17-2019, 09:41 AM   #18
whirnot
whirnot's Avatar
I had forgotten about those! I used to keep one for industrial emergency use. They work well and are flexible. Good solution!
Bill Worden
1929 Roadster
1951 Ford F1
Old 05-17-2019, 07:26 PM   #19
Ruth
I just wish it wasn't so RED!
Old 05-17-2019, 10:08 PM   #20
daveymc29
daveymc29's Avatar
Most times when you lose a fan belt can't one just drive on home and replace it there. The thermo cycle should keep the water circulating and with common sense driving you should be okay. On a tour is a different story and carrying the industrial belt seems prudent if you have the harmonic balancer. That's what I will plan on doing if and when I get one installed. (Thinking of putting on and one of Snyder 6.? heads on the roadster. I is a little underpowered with the old Police head and 3:54 gears, though I can shift down and cure that, just have to drive slower.
daveymc29 is offline   Reply With Quote
