04-02-2018, 09:22 AM | #1 |
36 pickup steering box adjustment help needed
I know most barners like 37 and later boxes. My 36 steering box is in good shape and I am trying to get the adjustment just right. I bought the kit to rebuild the 2 adjusters and installed them. I have 3 sources on how to adjust it correctly, and have followed them as best I could. I am feeling good about the adjustment, but would like any tips or help from anyone with more experience than myself. As always, Thanks for any help. Ron
04-02-2018, 05:52 PM | #2 |
Re: 36 pickup steering box adjustment help needed
Its important to have the sector on the crown of the worm when the wheels are straight ahead ,the cam adjustment does this ,on some models you can screw the tie rod end to sort this ,In my National service darter book (USA) they recommend you bend the sector,Ted
04-03-2018, 11:34 AM | #3 |
It should be slightly tight when you move the wheel through the centered position. It should feel like a very slight resistance. The best way to be able to get the correct adjustment (feel) is to remove the drag link. It can be done with both front tires off the grounf, but it is much more difficult to feel if the adjustment is correct.
04-04-2018, 06:34 AM | #4 |
What the guys say above.
Grab the steering wheel. Pull it towards you and push it away. Does it move? If it does, adjust the worm bearings. Drop the drag link. Find the straight ahead position on the steering box by counting turns from lock to lock and going half way. Turn the steering wheel past the straight ahead position. back and forth. Is there any resistance near the straight ahead? Yes? Jump to the next paragraph. No? carefully make the adjustment to make it tighter until you just start to feel a resistance as you pass the straight ahead position. This is the sweet spot for the steering. Yes? Is the resistance too heavy? if so slack it off and creep up against the sweet spot as described above. Once the steering box is in the sweet spot adjust the drag link so it corresponds with the wheels being in the straight ahead position. The above assumes the toe-in is already set correctly and that the kingpins, wheel bearings, tyre pressures and tie rod ends are all in good shape. If they are all good, after carrying out the above procedure that will be as good as it gets. The instructions are generic and can be applied to any steering box equipped vehicle. Mart. |
04-04-2018, 09:39 AM | #5 |
