01-14-2020, 06:27 PM | #1 |
Stoplight Stall
59A/B starts easily and runs great, but for some reason takes spells where it will die when stopping. Always re-starts instantly, but it is annoying and kind of a safety hazard.
Engine is 284 with mild street cam, Offy 425 heads and Offy 3 x 2 intake. Speedway 97 carbs with choke and idle circuits only on center carb. The linkage is adjusted so that the secondaries really are closed at idle. Pretty sure I have the float levels right at half an inch. Adjusted idle rpm to about 750. Adjusted idle jets closed to the point where idle RPM drops, and then open half a turn. Recently re-jetted all carbs from .045 to .047 to reduce overheating, but that did not improve the stalling. Ignition is Pertronix, and I have a nice big blue spark at idle. So what should I be looking at? Check the center float again? Open the idle jets? |
01-14-2020, 08:43 PM | #2 |
Re: Stoplight Stall
Are the idle mixture screws screwed all the way in on the outer carbs?
01-14-2020, 08:56 PM | #3 |
Re: Stoplight Stall
My thought is possibly float setting.
01-14-2020, 09:16 PM | #4 |
Re: Stoplight Stall
The outer 97's are built as secondaries, with no choke and no idle circuits, and they are on progressive linkage so they do not even start to open until about half throttle. All idle tuning is done on the center carb.
01-14-2020, 09:17 PM | #5 |
Re: Stoplight Stall
01-14-2020, 09:42 PM | #6 | |
Re: Stoplight Stall
Float needs to be set 9/32", measuring down from gasket surface of bowl to the top - adjacent to the hump - on the free end of the float... Just a wee bit lower than level when looking across it. This usually gives the magic 15/32" to 1/2" FUEL LEVEL.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
01-15-2020, 12:40 PM | #7 |
Re: Stoplight Stall
I will check the float again. The good thing about the Stromberg 97 is that you can pull the top off and actually measure the fuel level in the bowl with the fuel line and pump still hooked up.
Any other suspects for this problem? |
01-15-2020, 12:57 PM | #8 | |
Re: Stoplight Stall
hows the air filters, any difference if you remove air filters, any rpm increase. Phil NZ |
01-15-2020, 01:01 PM | #9 |
Re: Stoplight Stall
Did you synchronize the carbs?
01-15-2020, 01:32 PM | #10 |
Re: Stoplight Stall
Upon re-starting, does it sound, and act rich? Black smoke? These would be symptoms of flooding due to stopping. Make sure your floats are working under fuel pressure, it could be any of the three.
01-15-2020, 01:43 PM | #11 |
Re: Stoplight Stall
01-15-2020, 01:45 PM | #12 |
Re: Stoplight Stall
Starts up and runs fine after a stall. No stumbling or other indications of flooding, such as gas smell or black smoke. Fuel pressure is regulated to 2.5 psi and I have a gauge on the pump output, after the regulator.
01-15-2020, 06:30 PM | #13 |
Re: Stoplight Stall
Does it idle slowly,rough,or do anything odd before it dies--or just shut off instantly like you turned the key off?
I'm trying to decide whether it might be something affecting power to the coil or distributor when stopping...like a wire flexing or a switch doing something very weird. I once fixed a complaint like this in a '60's Chevy when the small spring on the disc in the starter solenoid broke and let that disc touch the starter motor contact and the ignition resistor bypass contact simultaneously when stopping quickly. It grounded the coil to the starter brushes. WEIRD! That's not your problem of course but odd things can happen. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
01-15-2020, 09:10 PM | #14 |
Re: Stoplight Stall
Checked vacuum?
01-16-2020, 08:24 AM | #15 |
Re: Stoplight Stall
You might try to isolate the problem by blocking off and disconnecting the linkage to the end carbs and run it on the center carb.
01-16-2020, 04:51 PM | #16 |
Re: Stoplight Stall
01-16-2020, 04:55 PM | #17 |
Re: Stoplight Stall
01-16-2020, 06:39 PM | #18 | |
Re: Stoplight Stall
I assumed you had progressive linkage. By blocking off the end carbs you are narrowing down the search of your problem. You seem knowledgeable, just keep hammering at it. Let us know what you find. |
