Old 08-11-2019, 07:32 PM   #1
frnkeore
frnkeore's Avatar
Default 18 to 14mm Spark Plug Adapter.
Where can I get adapters for my aluminum 18mm heads, to use 14mm plugs, either 3/8 or 3/4" reach?
Frank
frnkeore is offline   Reply With Quote
Old 08-11-2019, 07:52 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 18 to 14mm Spark Plug Adapter.
Not the right dude, so... Just no. Find the plugs. 14MM is not my style.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 08-11-2019, 10:41 PM   #3
Tinker
Tinker's Avatar
Use the 18mm plug. Snyder's has adapters for the model a (18mm to 14mm). I use one for my compression checker.
https://www.snydersantiqueauto.com/P...-a/spark-plugs
18mm Autolite 386 i think. Has the removal-able tops anyway to run raja ends. I can check. Aluminum 18mm is interesting anyway.
Not sure the advantage on this conversion setup. But I don't know the setup you got running?
Old 08-12-2019, 12:10 AM   #4
frnkeore
frnkeore's Avatar
My heads show a lot of corrosion in the spark plug threads. I'm wanting to play save and not sorry.
Old 08-12-2019, 12:13 AM   #5
Tinker
Tinker's Avatar
Maybe Heli coil then. Bit of jump to 14mm. not sure if an adapter would help anyways...
18mm with some anti seize might work. but who knows what condition, your condition is in.
Old 08-12-2019, 07:31 AM   #6
JSeery
JSeery's Avatar
I'm not sure what all type of inserts are available, but I have installed several sets of them on 4.6 Fords. The ones I used were not adapters, they come as a kit where you drill out the existing threads, tap new threads and then install the inserts. They are a life saver on the 4.6s! Looks like you can get the inserts in various lengths with just the taps.
Old 08-12-2019, 10:09 AM   #7
Bob C
Why would an adapter hold any better in the threads than a spark plug??
Bob
Old 08-12-2019, 10:23 AM   #8
frnkeore
frnkeore's Avatar
Because you no longer use the parent, aluminum threads.
Old 08-12-2019, 10:47 AM   #9
frnkeore
frnkeore's Avatar
I thought this would be a "no brainer", install once, with hi temp, Loc Tite and never have to worry about damaging the threads, beyond what they are now.
I didn't think I would have opposition to saving the original, aluminum threads.
Frank
Old 08-12-2019, 10:52 AM   #10
frnkeore
frnkeore's Avatar
JS, where do you get that re-threading outfit. It looks like it could be used, if it large enough to repair a 18mm hole and uses a non-extended reach plug.
Old 08-12-2019, 03:08 PM   #11
JSeery
JSeery's Avatar
You can just search Spark Plug Insets and you will get all kind of returns.
Here is a straight adapter 18mm to 14mm, but it does leave a lip where the installation nut is.
https://www.ebay.com/itm/Spark-plug-...-/141025801312
Old 08-12-2019, 05:30 PM   #12
tubman
tubman's Avatar
WOW! $180.00 for a set of eight? There's gotta be a better way.
tubman is online now   Reply With Quote
Old 08-12-2019, 06:48 PM   #13
frnkeore
frnkeore's Avatar
I did some searching today and found a set of 8, brass adapters, for $39.52 shipped, out of the UK.
Old 08-12-2019, 06:54 PM   #14
JSeery
JSeery's Avatar
The 4.6/5.4 kits are expensive but well worth it. The other options are not good. But no experience with other applications, so no idea there.
Old 08-13-2019, 03:50 PM   #15
40 Deluxe
You might find that re-thread kit available on loan from Autozone, O'Reilly, etc. That way you just buy the inserts.
Something to keep in mind is the need for heat transfer. Heli-Coils are a loose fit and I don't think transfer heat good enough. If a spark plug can't transfer heat to the head as intended, it will overheat and cause pre-ignition.
Inserts like pictured are far better. I agree with your plan! No need to have a plug or two blow out miles from home! And those heads are not going to know the difference between a 14MM plug and an 18MM.
Thread Tools
Display Modes
