12-20-2016, 10:45 PM | #1 |
Axel seal damage
I would like some thoughts on repairing the
Gouges left by axel seals on my axels. I have had some spray welded and turned back to standard, 1.135. My next step is to put a hatd chromed sleeve on the seal run. |
12-20-2016, 11:00 PM | #2 |
Re: Axel seal damage
speedi-sleeve, available at most real ( napa ) parts stores that sell bearings and seals
12-21-2016, 12:39 AM | #3 |
or find a seal that is thinner or make it thinner so it seats in a different place
12-21-2016, 07:21 AM | #4 |
The seals are inside the axle housings. I have not seen the damage you notice, since the axle can not touch the seal metal housing once the wheel hub is installed. Could you post a photo. Often the underside of the axle housing gets damaged. There is a hard sleeve to repair this damage also.
12-21-2016, 07:32 AM | #5 |
These axles float a little but either way it is common for the rubber in a seal to harden and wear a groove in the metal it touches. Sometimes the seal can be installed so it is in a slightly different position and sometimes stuff needs to be repaired or replaced. Building up the groove and machining I would think be sufficient for a long time.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
12-21-2016, 08:04 AM | #6 |
12-21-2016, 10:00 AM | #7 |
This seal conversation u mention JM.
Is there a source or photos showing and describing this method? |
12-21-2016, 10:29 AM | #8 | |
https://www.fordbarn.com/forum/showth...ight=axle+seal ....and here is a picture of these seals....
12-21-2016, 08:31 PM | #9 |
Nothing easier than sliding a Timken Company Redi-Sleeve over the worn axle seal area.
Chisel Evil Lurks...for those that don't carry a side arm!!! |
12-22-2016, 01:28 AM | #10 |
Thanks fellows. I will post some picture soon. There doesn't seem to be a sleeve to fit our axels. I have contacted a company here (Can.) they are going to make some and hard chrome them for us.
12-22-2016, 07:45 AM | #11 |
Contact BDI in Canada. The web site below should find a location.
http://bdi-usa.com/ Last edited by Terry,OH; 12-22-2016 at 07:50 AM. |
12-22-2016, 07:48 PM | #12 | |
Looks like it fits to a 32 axle.
12-22-2016, 08:01 PM | #13 |
Did you check a catalog?
12-23-2016, 05:54 PM | #14 |
Sometimes you need to get a little creative and not believe everything you read in the newspaper. Part # 99116 and a hair dryer and it slips right on. 5 so far and no problems.
12-27-2016, 12:53 PM | #15 |
Very interesting. I learn something new every day.
Kirk
1953 Ford F100 1950 Ford F47 (F1) 1940 Ford Pickup |
Thread Tools | |
Display Modes | |
