03-27-2020, 09:01 AM | #1 |
bolt torque difference iron block & Aluminum Head
Ok, up popped a rattle in my Galaxie 289 water pump that has to be replaced. The engine had been converted to aluminum heads. The shop manual calls out 12-15 ft lbs, but that's for cast iron block and heads. Any idea what torque to use on the aluminum heads? Thanks Rob
03-27-2020, 09:51 AM | #2 |
Re: bolt torque difference iron block & Aluminum Head
As I remember, those are 5/16" bolts so the bolt itself is the limiting factor. 12-15 ft. lbs. should be OK in aluminum as spark plugs in aluminum heads are torqued to around 20 ft. lbs.
03-27-2020, 02:37 PM | #3 |
the water pump doesnt bolt to any head.nothing would change.
03-27-2020, 03:42 PM | #4 |
