Old 09-23-2016, 04:15 PM   #1
hoffernsp
hoffernsp's Avatar
Default 1951 Merc wiring sizes
I plan on wiring my 51 Merc from scratch. I have the wiring diagram but does now show wire sizes. Anyone have a table or reference for the individual component wire gauges?
hoffernsp is offline   Reply With Quote
Old 09-23-2016, 05:22 PM   #2
Drbrown
Drbrown's Avatar
Default Re: 1951 Merc wiring sizes
I recently researched '41 thru '48 Ford manuals and service bulletins I have regarding OE wire gauges and colors and prepared the attached "Tabulation Wire Circuits." I note it pertains to 6 volt systems and that I found only a few contradictions in the publications. Forum member JSeery also has some data on this subject.
If you are going to operate a 6 volt system this data should help you. You may also wish to either simulate the OE wire colorings or try to find someone who reproduces the colors/combinations.
Drbrown is offline   Reply With Quote
Old 09-23-2016, 05:29 PM   #3
JSeery
JSeery's Avatar
Yea, I can post the diagrams again.
File Type: jpg flathead-Ford-49-51-turnwireharness.jpg (74.4 KB, 22 views)
File Type: jpg ford-f100-pickup-truck-wiring-diagram-1953-1954-1955-1956.jpg (90.6 KB, 21 views)
Old 09-23-2016, 06:30 PM   #4
hoffernsp
hoffernsp's Avatar
Wow thanks to you both. That's exactly what I need to go forward
Old 09-23-2016, 07:12 PM   #5
JSeery
JSeery's Avatar
That chart/list Drbrown made is really cool. That is a lot of work, I know, I built something similar but not as elaborate.
Old 09-24-2016, 10:02 AM   #6
rotorwrench
rotorwrench's Avatar
The only ones I didn't see here are the turn signal diagrams and their interrelation to the brake light system. There are diagrams available on flea-pay that will have the colors but they won't have the wire sizes (most likely all 16 AWG). Larger gauges were used for the high current draw stuff as noted in the other documents. If you have electric overdrive, it uses larger gauges too.
Old 09-24-2016, 12:07 PM   #7
JSeery
JSeery's Avatar
I have turn signal diagrams as well if anyone is interested.
Old 09-25-2016, 12:50 PM   #8
Drbrown
Drbrown's Avatar
Overdrive circuits .... I have a BW 10I OD and a 12 volt system. To avoid OD solenoid "holding" malfunctions due to current draw, it uses a 30 amp fuse and 10 gauge wiring. I suspect 10 gauge wire is okay for 6 volts as well.
Sidenote: Ground the OD housing directly to the car body/frame.
